251 user(s) are online (180 user(s) are browsing Forums)
-=Jeff=- WooHoo!!! New system setup
Bartlett, IL
573 Posts
So I was able to get some $$ together and bought a second Arc Audio Ks 300.4 (90x4) so I have 2 now
I also was able to buy a Eclipse CD8053 which has capability for 3 way active system. So I have a New plan
one channel for EACH speaker
Will use the band pass capability of the HU to both the 4" midrange and 6.5" midbass. then the Amps will handle the HP for the 4" and LP for the 6.5.
Hopefully it will all work out
Posted on: 2010/11/4 22:18
-=Jeff=-
1990 Corvette ZR-1 #1051
Matatk Re: WooHoo!!! New system setup
Can't wait to see/hear this!
Posted on: 2010/11/4 22:23
-=Jeff=- Re: WooHoo!!! New system setup
Bartlett, IL
573 Posts
Neither can I..
It will be nice to ditch the passive Crossovers in favor of Active stuff.
Also has a Aux in, so might even try to use my Droid with it..
but for now I need to order a couple more pieces for wiring...
Posted on: 2010/11/4 22:37
-=Jeff=-
bogus Re: WooHoo!!! New system setup
Exciting!
Posted on: 2010/11/4 22:43
Bartlett, IL
573 Posts
Yes Very.. Wonder how well Tweeters will hold to 90watts.. LOL
the nice thing is I can tweak levels for each channel. PLus the 24dB slope crossover function.. going to be a busy winter
Posted on: 2010/11/4 22:49
-=Jeff=-
You should find a used spectrum analyzer... you can now justify it. Otherwise, you will be so damned screwed up with all the crossover settings, you will have subbass coming from the mids.
Posted on: 2010/11/5 1:14
Bartlett, IL
573 Posts
Too bad I don't work where we use them anymore, I could have borrowed one.
Posted on: 2010/11/5 1:16
-=Jeff=-
oh, that sucks.
Posted on: 2010/11/5 1:20
Bartlett, IL
573 Posts
yeah not to big a deal. I do have some Ideas for Crossover points.. so I will have a starting point at least
Posted on: 2010/11/5 3:15
-=Jeff=-
that helps...
Posted on: 2010/11/5 3:55
Bartlett, IL
573 Posts
Helps to have a plan
when i was trying to research the HU I am buying I cam across this thread:
CD8053 with active 3way Plus Sub
it is a similar set-up as far as drivers.. so here is what I am thinking for the initial setup
Speakers:
Woofers (using either eD EU700s or my 9kv.2s)
Mid bass CDT EF6
Mid Range CDT CL4
Tweeter TW24
Initial Crossover points:
Woofer: LP - 80hz, 24dB/oct slope
Midbass: HP - 80hz, 24dB/oct slope, LP 500hz 12dB/oct slope
Midrange: HP 500hz 12dB/oct slope, LP - ~5000hz, 24dB/oct slope
Tweeter: HP - ~5000hz, 24dB/oct
the two 12dB/Oct slopes are due to the limitation of the Active Crossovers of the Amplifier, since the HU has a 3-way active setting I am using the Amps Crossovers to split the midrange signal
Plan is one amp will run the woofers and the midbass, the second will run the midrange and tweeter.
I am thinking it should sound fairly decent to start with, then the tweaking begins
Posted on: 2010/11/5 11:59
-=Jeff=-
Bartlett, IL
573 Posts
Amp #2 came in last week.. I should have the HU this week
Posted on: 2010/11/15 5:06
-=Jeff=-
exciting!!!
Posted on: 2010/11/15 5:23
