152 user(s) are online (120 user(s) are browsing Forums)
1st Gear: 3.06
2nd Gear: 1.62
4th Gear: 0.70
Reverse: 2.29
Danspeed1 Briggs and Straton
Mooresville, North Carolina
1121 Posts
Hello,
I am working on trying to repair my 15 year old briggs and straton leaf blower; thus far unsuccessfully. It ran three weeks ago, sat till now and it won't run. This is the part that gets me. Fuel is fresh, and I have spark. I sprayed Eather (I spelled it wrong I know) into the spark plug hole (new plug too) and it won't even kick over for a second. I am thinking even though I have spark maybe the condenser went bad... so I may be seeing spark but its not enough to ignite the starting fluid.
What do you think?
P.S. I bought another corvette today... pictures to follow,
Dan
Posted on: 2010/11/19 20:48
1972 Chevelle SS 454
1995 Corvette Convertible
1996 Ford Explorer
2009 Cadillac CTS-v
tjpreul Re: Briggs and Straton
The most common problem is with the carburetor or the diaphram. I'm guessing this is a 4 stroke walk behind. What color is the spark. If it looks strong you should be alright. I typically take the carb off and spray it out. When it is off check the diaphram under it (it is also the fuel pump). These will strech out.
Posted on: 2010/11/19 22:13
BillH Re: Briggs and Straton
Yea, on the diaphram (if it has one). If it has spark but won't fire ether, something's strange. I usually use carb clean to get this kinda stuff running. 5 second shot in the plug hole.
If you pull and pull and no start, the plug should be damp.
Doesn't have a fuel tank shut off that you forgot about, does it?
Posted on: 2010/11/19 23:19
Danspeed1 Re: Briggs and Straton
1121 Posts
Good Idea's but shouldn't it run off the starting fluid then die. This is a really strange problem because I have the three things you need for an engine to run, yet it isn't running for a second. I have spark, I have fuel, I have air????
Doesn't make sense. Spark looks bluish yellow,
DG
Posted on: 2010/11/20 0:42
1996 Ford Explorer
2009 Cadillac CTS-v
Yea, should run on the ether. Wonder if a valve's stuck open (if it's a 4 stroke). Put your finger over the hole & see if you have compression.
Posted on: 2010/11/20 0:50
I put a small capful of gas into the carb. You will have to pull it a few times to see if it will fire. Also on the 4 stroke carbs some models you have to put the bolt back in if you have the cleaner off.
Posted on: 2010/11/20 1:06
1121 Posts
Good idea, I will give that a try and post back later.
DG
Posted on: 2010/11/20 3:25
1996 Ford Explorer
2009 Cadillac CTS-v
bogus Re: Briggs and Straton
20860 Posts
Odd... A lack of compression would result in a nearly effortless pull.
I am still thinking it's the coil or capacitor.
Posted on: 2010/11/20 6:13
