iCorvette | How do I remove the rubber ball joint boots? | ||
I got some new front control arms and want to put poly ball joint boots on, I can't seem to figure out how the original ones are attached, don't want to rip it... or should I leave it.
the bushings on them are beautiful, I am very hesitant to slap polys on them, should I just install them as they are? your comments appreciated.... |
Posted on: 2010/12/31 21:18
bogus | Re: How do I remove the rubber ball joint boots? | ||
are these arms NEW or just new to you?
Posted on: 2010/12/31 21:36
BrianCunningham | Re: How do I remove the rubber ball joint boots? | ||
Didn't they come with BJ's?
Is so, if they haven't dryrotted, I'd leave them. |
iCorvette | Re: How do I remove the rubber ball joint boots? | ||
They are NOS arms from corvette recycling, they are supple as the day they were made....
should I leave the boots as well? |
Posted on: 2010/12/31 21:43
No reason not to.
Stockers are what I'm running on my new setup. <------- (see Avatar) |
Posted on: 2010/12/31 22:03
hello
Posted on: 2010/12/31 22:07
I thought the stuff i see on your avatar is a forgone conclusion... check this out.... http://www.eng-tips.com/viewthread.cfm?qid=287903&page=1 |
Posted on: 2010/12/31 22:08
