283 user(s) are online (214 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
smooth Fuel rail ?
Formerly "Aquavet" in Pa.
386 Posts
.....along with all of my other projects, I have a '96 block I'm gathering parts for. I have a guy that says he has the fuel rail setup, but its for a '93LT1. Nothing ever changed about them through the entire lt1 series of engines correct?
Thanks, alan
Posted on: 2011/1/7 13:44
Alan
2001 Navy Blue Metallic
rklessdriver Re: Fuel rail ?
Incorrect.
92-93 had the crossover in the rear of the fuel rail.
94-96 have the crossover in the front of the fuel rail.
You can use 92-93 rails on any year LTX intake manifold however 94-96 rails will not fit on 92-93 intake manifolds as they are cast solid behind the TB.
Also be careful of which rails you buy because the Y body, F body and B Body all use different connectors and are located in different places for the fuel lines.
Posted on: 2011/1/7 16:59
smooth Re: Fuel rail ?
386 Posts
Aha! Thanks Will. I can always count on you guys!
Posted on: 2011/1/8 2:11
Alan
