220 user(s) are online (129 user(s) are browsing Forums)
Print in friendly format Send this term to a friend  Ruby
Refers to 1993 Anniversary Editions.
These are the actual cars honored as anniversary cars. They have RPO Z25 to prove it....
jsncable Control Arm Shaft Torque ?
Jacksonville, FL
10 Posts
I've looked for two hours now, in the service manual and on the internet and cannot find the torque spec for the upper control arm shaft nuts. I've replaced the upper bushings and need to reinstall..
Thanks,
Jason
1984
Posted on: 2011/1/25 15:12
PLRX Re: Control Arm Shaft Torque ?
SoCal
212 Posts
Thanks,
Jason
1984
That's aluminum, 40 lbs-ft.
I've done it 5 times and I'm alive. Ensure you use red thread locker.
Posted on: 2011/1/26 5:18
jsncable Re: Control Arm Shaft Torque ?
Jacksonville, FL
10 Posts
thanks!
Posted on: 2011/1/26 17:19
Steve40th Re: Control Arm Shaft Torque ?
1114 Posts
I also used a finger nail polish on the bolt threads to nut to verify over time whether or not it backed off any.
Posted on: 2011/1/27 4:16
Ko'u ohana aia ku'a ikaika
