jsncable | Control Arm Shaft Torque ? | ||
I've looked for two hours now, in the service manual and on the internet and cannot find the torque spec for the upper control arm shaft nuts. I've replaced the upper bushings and need to reinstall..
Thanks, Jason 1984 |
Posted on: 2011/1/25 15:12
PLRX | Re: Control Arm Shaft Torque ? | ||
That's aluminum, 40 lbs-ft. I've done it 5 times and I'm alive. Ensure you use red thread locker. |
Posted on: 2011/1/26 5:18
jsncable | Re: Control Arm Shaft Torque ? | ||
thanks!
Posted on: 2011/1/26 17:19
Steve40th | Re: Control Arm Shaft Torque ? | ||
I also used a finger nail polish on the bolt threads to nut to verify over time whether or not it backed off any.
Posted on: 2011/1/27 4:16
Ko'u ohana aia ku'a ikaika |
