250 user(s) are online (184 user(s) are browsing Forums)
MikeG Injectors
Bronston,Ky 42518
54 Posts
I have a set of injectors from my 93. All ohm out ok. They have the yellow tops. I have no idea what brand they are. If you need them they are yours for free.
Posted on: 2011/1/30 22:51
bogus Re: Injectors
Yellow? I wonder if they are Accel?
Nice deal!
Posted on: 2011/1/31 0:02
madmike21 Re: Injectors
1 Posts
Hello, I have a used tuneport 350 that has been sitting for a year and may need some injectors since I don,t have a history on it.May put it in my 84 C4 once I run it on my test stand.I would like to try the injectors if no one needs them worse than me. THANKS! MADMIKE21.
Posted on: 2011/1/31 3:24
bogus Re: Injectors
Mike,
Welcome!
I assume you have converted your 84 to the later TPI injection? If so, these might work... my concern is flow rate. The later LT1 used a higher rate injector than the earlier L98 systems.
Posted on: 2011/1/31 4:57
MikeG Re: Injectors
Bronston,Ky 42518
54 Posts
They are yours, PM me an addy to send them to !
Posted on: 2011/1/31 11:02
Matatk Re: Injectors
Mike, if you upgrade that 84 to a TPI unit, you'll also need a later fuel pump
Post some part numbers for the injectors and we'll figure out what they are - flow rate, etc.
Posted on: 2011/1/31 13:20
MikeG Re: Injectors
Bronston,Ky 42518
54 Posts
MATATK, I have looked at these things several times and can;t find a number or name on them anywhere. Just a black injector body with yellow tops.
Posted on: 2011/1/31 19:59
bogus Re: Injectors
sound like Accel...
Posted on: 2011/1/31 20:51
MikeG Re: Injectors
Bronston,Ky 42518
54 Posts
Still have these if anyone is interested.
Posted on: 2011/3/18 20:43
fox_guy48 Re: Injectors
Katterbach Germany
78 Posts
i will take them if you still have them pm sent
Posted on: 2011/5/9 19:28
92 Polo Green, MSD Ignition, 1.6 roller rockers, TPIS Headers, Exhaust, Airfoil, Stage 2 Chip.
MikeG Re: Injectors
Bronston,Ky 42518
54 Posts
PM sent !
Posted on: 2011/5/15 16:56
