Browsing this Thread:
2 Anonymous Users
MikeG | Injectors | ||
I have a set of injectors from my 93. All ohm out ok. They have the yellow tops. I have no idea what brand they are. If you need them they are yours for free.
Posted on: 2011/1/30 22:51
bogus | Re: Injectors | ||
Yellow? I wonder if they are Accel?
Nice deal! |
Posted on: 2011/1/31 0:02
madmike21 | Re: Injectors | ||
Hello, I have a used tuneport 350 that has been sitting for a year and may need some injectors since I don,t have a history on it.May put it in my 84 C4 once I run it on my test stand.I would like to try the injectors if no one needs them worse than me. THANKS! MADMIKE21.
Posted on: 2011/1/31 3:24
Mike,
Welcome! I assume you have converted your 84 to the later TPI injection? If so, these might work... my concern is flow rate. The later LT1 used a higher rate injector than the earlier L98 systems. |
Posted on: 2011/1/31 4:57
MikeG | Re: Injectors | ||
They are yours, PM me an addy to send them to !
Posted on: 2011/1/31 11:02
Matatk | Re: Injectors | ||
Mike, if you upgrade that 84 to a TPI unit, you'll also need a later fuel pump
Post some part numbers for the injectors and we'll figure out what they are - flow rate, etc. Matthew |
Posted on: 2011/1/31 13:20
MATATK, I have looked at these things several times and can;t find a number or name on them anywhere. Just a black injector body with yellow tops.
Posted on: 2011/1/31 19:59
sound like Accel...
Posted on: 2011/1/31 20:51
Still have these if anyone is interested.
Posted on: 2011/3/18 20:43
fox_guy48 | Re: Injectors | ||
i will take them if you still have them pm sent
Posted on: 2011/5/9 19:28
92 Polo Green, MSD Ignition, 1.6 roller rockers, TPIS Headers, Exhaust, Airfoil, Stage 2 Chip. |
PM sent !
Posted on: 2011/5/15 16:56
