250 user(s) are online (195 user(s) are browsing Forums)
« 1 (2)
Churchkey Re: Did rear bearings and brakes, something weird on the right rear brake. Look
69 Posts
Nice find Steve40th.
I recall someone mentioning that the pad may not be seated properly in the caliper :~)
Posted on: 2011/2/23 14:14
Steve40th Re: Did rear bearings and brakes, something weird on the right rear brake. Look
1114 Posts
Stranger things have happened. Thanks
Posted on: 2011/2/23 16:43
Ko'u ohana aia ku'a ikaika
Matatk Re: Did rear bearings and brakes, something weird on the right rear brake. Look
Glad you found the issue!
Posted on: 2011/2/24 3:34
1114 Posts
And one final shot of the rotor after 25 more miles. I think I fixed it. Thanks for all the help guys.
jpg  DSCF2542.jpg (128.37 KB)
236_4d67e19072759.jpg 2100X900 px
Posted on: 2011/2/25 17:06
bogus Re: Did rear bearings and brakes, something weird on the right rear brake. Look
jaa1992 wrote:
Steve40th wrote:
jaa1992 wrote:
Caliper spread maybe? Caused by the wobbly bearing?
Try a rebuilt caliper on that side?
Check the mount as well.
If the aluminum caliper is spread, I think it would be cracked or show signs of wear. I just cant see aluminum forged calipers bending. Not that its impossible,
Nope, they spread without any visible signs
I don't have one off the car or I could do some measurements.
Read the rest of the thread - yea, the bad anti-rattle plate messd up the pad alignment. I don't use them anyway
I know the fronts can spread, but can enough heat be generated in the rear? It takes a lot of constant heat to spread these. I know it is possible, but mostly in the fronts, they handle 70% of the stopping force. Hence, 70% of the temperature!
Posted on: 2011/2/25 18:08
RestoMod57 wrote:
I used to recommend to customers that new rotors be cut, but only with a computerized on-the-car lathe. Two reasons, the quality of some rotors was sub-standard (especially Chinese produced ones), and secondly the on-car lathe matches the cut to the hub and its wobbles.
And this is why I only buy NAPA Made in the USA rotors.
I have NEVER had a problem with these.
Posted on: 2011/2/25 18:09
1114 Posts
Randy at DRMsaid yes the rearas can get enough heat, especially if you throw a bias spring which throws more bias to the back, and you road race. Auto Cross and drag racing, nope. Canyon running maybe.
Funny thing on the C5 fronts people run. They ar finding those spreading and recommending using the C6 calipers. NOT ZO6 calipers from the C6 as they are not so good.
Posted on: 2011/2/25 18:13
« 1 (2)
