Churchkey | Re: Did rear bearings and brakes, something weird on the right rear brake. Look | ||
Nice find Steve40th.
I recall someone mentioning that the pad may not be seated properly in the caliper :~) |
Posted on: 2011/2/23 14:14
Steve40th | Re: Did rear bearings and brakes, something weird on the right rear brake. Look | ||
Stranger things have happened. Thanks |
Posted on: 2011/2/23 16:43
Ko'u ohana aia ku'a ikaika |
Matatk | Re: Did rear bearings and brakes, something weird on the right rear brake. Look | ||
Glad you found the issue!
Matthew |
Posted on: 2011/2/24 3:34
And one final shot of the rotor after 25 more miles. I think I fixed it. Thanks for all the help guys.
Posted on: 2011/2/25 17:06
bogus | Re: Did rear bearings and brakes, something weird on the right rear brake. Look | ||
I know the fronts can spread, but can enough heat be generated in the rear? It takes a lot of constant heat to spread these. I know it is possible, but mostly in the fronts, they handle 70% of the stopping force. Hence, 70% of the temperature! |
Posted on: 2011/2/25 18:08
And this is why I only buy NAPA Made in the USA rotors. I have NEVER had a problem with these. |
Posted on: 2011/2/25 18:09
Randy at DRMsaid yes the rearas can get enough heat, especially if you throw a bias spring which throws more bias to the back, and you road race. Auto Cross and drag racing, nope. Canyon running maybe. Funny thing on the C5 fronts people run. They ar finding those spreading and recommending using the C6 calipers. NOT ZO6 calipers from the C6 as they are not so good. |
Posted on: 2011/2/25 18:13
