postalvette | ECM codes | ||
Anyone have a list of the ECM codes for an 84
Posted on: 2011/3/3 5:51
bogus | Re: ECM codes | ||
DTC codes for 1984:
12 - System normal/communications ok/end of diagnostics 13 - O2 Sensor 14 - Coolant Sensor low voltage 15 - Coolant Sensor high voltage 21 - Throttle Position Sensor high voltage 22 - Throttle Position Sensor low voltage 24 - Vehicle Speed Sensor 33 - MAP Sensor low voltage 34 - MAP Sensor high voltage 42 - Electronic Spark Control 44 - Lean Exhaust 45 - Rich Exhaust 51 - PROM 55 - ECM Report back what you find, and we can start diagnosing! |
Posted on: 2011/3/3 6:19
postalvette | Re: ECM codes | ||
Came up with code 21. Throttle postion sensor. Any idea where this is located. Will check wiring first then replace unless you have some other things I could check.
Posted on: 2011/3/3 23:51
the TPS is on the throttle body somewhere... I just don't know where.
Posted on: 2011/3/3 23:59
This 84 is my son's car but I have an 82. I've got the gm shop manual for mine (both cars have the same engines technically)and found the throttle position sensor, it's on the rear throttle body. I read a blog that says you may be able to do adjustments but I can't see how and the manual does'nt mention anything. The wiring and connector look good so guess I'll have to go shell out some dinero for a new one, hope it fixes the check engine light will let you know. Thanks again for the codes!
Posted on: 2011/3/4 1:20
The blog may be right. Many times, we owners find ways around things that the mfg never considered... or don't want us to know.
Case in point are the procedures for doing the heater core. It's an absolute nightmare, but done the easy way... saves half the labour. |
Posted on: 2011/3/4 1:54
Matatk | Re: ECM codes | ||
Found this online - apparently it's from autozone's free online database, but I am not signed up for that:
Any time the TPS is removed, it must be readjusted according to the following procedure. Throttle Position Sensor (TPS) See Figure 9 http://repairguide.autozone.com/znetr ... dium/0900c152800835ee.gif Fig. Fig. 9: Throttle Position Sensor (TPS) adjustment An accurate digital voltmeter is needed to perform this adjustment. Remove the TPS attaching screws and apply thread locking compound to the screws. Reinstall the screws loosely. Install three jumper wires between the TPS and the TPS wiring terminal connections, as shown in the accompanying illustration. Turn the ignition ON and measure the voltage between the A and B terminals of the TPS. Rotate the TPS to obtain a voltmeter reading of .525 .075 volts. Tighten the screws. Turn the ignition OFF, remove the jumpers, and connect the TPS wiring to the TPS. |
Posted on: 2011/3/4 3:01
Thanks for the info. Installed the new tps, it came with instructions on how to adjust it although the values were a little different. But what a DIFFERENCE!! Took care of the check engine lite but mainly the idle problem, smooth!!
Posted on: 2011/3/6 5:46
awesome!!!
Posted on: 2011/3/6 18:16
