Steve40th | New U Joints, should I clean and re grease them? | ||
I was thinking of cleaning and re-greasing my brand new u Joints for my half shafts. Yes or no.
Posted on: 2011/3/8 1:45
Ko'u ohana aia ku'a ikaika |
CentralCoaster | Re: New U Joints, should I clean and re grease them? | ||
I say no. I recall spicer was very specific about the amount of grease inside the ujoints. I thought I read that in the instructions.
I don't know how greasable ujoints factors into that, maybe they just need a quick squirt every few years. I burned up my stockers at about 80K, the grease had finally found its way out or was otherwise turned to dust. |
Posted on: 2011/3/8 2:01
Matatk | Re: New U Joints, should I clean and re grease them? | ||
Are they sealed units or with a zerk?
[edit] Zerk fitting: Cleaning them as in removing the grease in them now? No. But they are shipped not fully greased. Grease them through the zerk until some of the packing grease squirts out. http://www2.dana.com/pdf/J3299-2-DSSP.PDF Matthew |
Posted on: 2011/3/8 2:35
Steve40th | Re: New U Joints, should I clean and re grease them? | ||
Brand new. Black looking grease in there, no zerk, factory GM
Posted on: 2011/3/8 3:00
This was on a federal mogul FAQ:
"Q. I have a Super Strength non-greaseable joint - that means I don't have to grease it, right?" A. Wrong! Pack the cups full of grease during installation, after that 'you're on your way'." |
Posted on: 2011/3/8 3:08
Well I'll be damned. I'll redo mine next time I'm in there.
Posted on: 2011/3/8 8:10
Love the warning symbol on page 3 btw.
Posted on: 2011/3/8 8:14
So, just fill them full of grease. No need to clean the old, different grease out?
Posted on: 2011/3/8 16:04
No need to remove the factory stuff in there.
Posted on: 2011/3/8 16:05
Okay. I have a MOBIL 1 synthetic bearing grease I will use to fill them up. I will push it in . The housing of the u joint is solid too. |
Posted on: 2011/3/8 16:08
