216 user(s) are online (122 user(s) are browsing Forums)
joeld Casting Hole Plug(lead slug) loose
In the process of re-building a Q-Jet, found one of the lead plugs in the body loose. It's not the bigger ones under the metering rods, it's a small 5/32 plug.
Anybody ever replace these? Thought about using JB Weld, not sure if this would hold up being in gas constantly. Could drill & tap to use a screw to seal with? Or some high lead content solder?
Any ideas?
Thanks
Posted on: 2011/6/18 16:30
BillH Re: Casting Hole Plug(lead slug) loose
Posted on: 2011/6/18 17:02
joeld Re: Casting Hole Plug(lead slug) loose
Thanks Bill,
Seems like JB Weld is what people use around the plugs for a little insurance. I might tap the hole and then use JB around the threads. Or just use the JB.
Posted on: 2011/6/18 19:52
joeld wrote:
Thanks Bill,
I'd upgrade to the Waterweld but, the only real experience I have with regular JB is with brake fluid (pressure bleeder) and it started to fail after 2 years.
Posted on: 2011/6/18 20:48
Matatk Re: Casting Hole Plug(lead slug) loose
22947 Posts
I thought guys used epoxy on those? I have no personal experience.
Posted on: 2011/6/19 2:57
22947 Posts
Look here for suggestions:
http://www.hotrodders.com/forum/leaking-quadrajet-138013.html
Apparently epoxy is what they used when built.
JB weld will fail after heat cycles.
One person says drill and tap it, another says use permatex repair stick.
Just a few things to consider.
Posted on: 2011/6/19 3:03
Looks like JB's been used in some apps. And 2 other epoxy part numbers:
http://speedtalk.com/forum/viewtopic.php?f=1&t=17723&start=0
And a pic of the pulgs epoxied (good article).
http://books.google.com/books?id=DwUM ... for%20carburetors&f=false
Posted on: 2011/6/19 13:25
OK, just a quick update. I decided to tap the hole and use a 10-32 screw. I "wrapped" the threads with the Waterweld from JB Weld, this was the first time using this particular epoxy. It is NOT user friendly trying to finese around a small screw. It would be great for a larger hole.
Carb is back on and running very nice as of right now.
I'll do another update in a few years on the sealer on how good it stands up to gas!
Thanks for the replies!
Posted on: 2011/6/22 21:18
