156 user(s) are online (79 user(s) are browsing Forums)
1st Gear: 2.43
2nd Gear: 1.49
4th Gear: 0.75
Reverse: 2.07
matts85vet computer tune needed for 85 with new gear ratio
Toledo, Ohio
58 Posts
3.75 gears are in!
my chip was done previously by jesse azzato
any suggestions?
Posted on: 2011/6/23 2:19
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
bogus Re: computer tune needed for 85 with new gear ratio
PM mseven.
Posted on: 2011/6/23 7:00
Matatk Re: computer tune needed for 85 with new gear ratio
22810 Posts
Did you only change the gear ratio? Then why do you need a tune?
Posted on: 2011/6/24 15:15
matts85vet Re: computer tune needed for 85 with new gear ratio
Toledo, Ohio
58 Posts
yes just the gear ratio
it runs pretty rich also.
i was told that the tune may not be the best quality.
Posted on: 2011/6/25 2:30
22810 Posts
If you are trying to change the tune for the speedometer, it's controlled by plastic gears in the trans.
If you want to change the tune because you don't like the one in there, try Mick on here or PCM4less.
Posted on: 2011/6/25 3:12
