214 user(s) are online (166 user(s) are browsing Forums)
kelley optispark
thomasville ga
122 Posts
i think i know why they called it that,,,i have a nice light show under my water pump,, and a snapping, i think i found why i have a skip, now i need to climb under to see if i can see whats going on,or is it a feel whats loose thing?
Posted on: 2008/1/29 0:48
94z07 RE:optispark
94 Posts
If you're seeing sparks in a dark engine bay, I would suspect the ignition wires before I would suspect the opti. Either way, digging in to it will show you where the fault lies.
Let us know what you find, please.
Posted on: 2008/1/29 0:55
Business makes progress. Fortune passes everywhere.
Ramrod RE:optispark
S. California
296 Posts
I had a new coil wire back itself off the cap! Silicone grease them boots and try and purge any air trapped in the boot when you put it on.
Posted on: 2008/1/29 1:50
kelley RE:optispark
thomasville ga
122 Posts
if the cap is cracked will it still run? still can`t get under it to see
Posted on: 2008/1/29 12:45
Ramrod RE:optispark
S. California
296 Posts
Yeah, probably but not very good. It could be bad wires too.
Posted on: 2008/1/30 1:09
kelley Re: optispark
thomasville ga
122 Posts
end of plugwire burned off,, wasen`t pluged in all the way, and been that way for a while, SO replace wires and cap,, :silent:
Posted on: 2008/2/5 17:33
Ramrod RE:optispark
S. California
296 Posts
That sounds like the boots pushed themselves off, like I said silicone grease the insides of the boots and make sure they are purged of air or It'll happen again. If you haven't done the wires before pull the front wheels and fender wells. It'll make it easier to change them out. Not exactly "Swear-Free" but it cuts down the explectives! I had to Dremel the AC mount bracket to sneak the drivers side wires through. Have fun
Posted on: 2008/2/6 1:47
