309 user(s) are online (277 user(s) are browsing Forums)
Very stout.
Fredbird 1991 L98 Direct replacement Set of Injectors
San Antonio, Texas
103 Posts
I have a 1991 Corvette with the L98 Engine. I'm looking for a direct replacement set for that engine including all the O rings.
From what I'm reading it doesn't sound like I really need flow matched unless there's a nelegable price difference.
I don't want to make any modifications to the system if possible. So direct drop in's would be great!
Thanks for your help!
Posted on: 2011/7/7 2:27
1Fast04Vert Re: 1991 L98 Direct replacement Set of Injectors
You are in the right place, FIC is best in price and service.
Posted on: 2011/7/7 2:47
FICINJECTORS Re: 1991 L98 Direct replacement Set of Injectors
Gold Sponsor Vendor
117 Posts
Ho FredBird. All our sets are flow matched, we do not charge extra for the service, and it is an important one, making sure each cylinder gets the same amount of fuel can improve mileage, driveability, and prevent one cylinder from running lean or rich, a condition that your O2 sensors can't pick up.
I have our Bosch Design III's, flow matched, drop in replacement, viton o-rings installed, and our 3 year no questions warranty.
With the install kit, which comes with all Fel-Pro gaskets needed for the change, as well as the rail o-rings for the L98.
For the injectors and the install kit it's $199.95 plus $7 shipping.
~Rich
Posted on: 2011/7/7 4:55
