239 user(s) are online (191 user(s) are browsing Forums)
istter1 weather striping for 87 corvette coop
Bakersfield Ca
2336 Posts
Getting ready to paint this vehicle and the weather striping is going to be an issue. I hear there are many good kits and some that just don't last. Would apperaciate your opinions
jpg  IMG00040-20100810-1641.jpg (273.99 KB)
5144_4e15cdef5770b.jpg 2048X1536 px
Posted on: 2011/7/7 15:18
bogus Re: weather striping for 87 corvette coop
nice looking ride!
The best sources are Corvette-Rubber.com, Wilcox and GM itself.
You want the latest revision material from the 1996 Corvette. It is a better material that won't break down and won't tear as easily.
Posted on: 2011/7/7 15:23
TommyT-Bone Re: weather striping for 87 corvette coop
33763 Posts
Heck, your car looks better before painting than mine after painting. I agree totally with Andy on the weather stripping.
Posted on: 2011/7/7 15:31
istter1 Re: weather striping for 87 corvette coop
Bakersfield Ca
2336 Posts
Thanks for the complement . Fun to drive. Tearing apart the clutch hydralic systen later to try and find out for the fifth time why it keeps failing. Nex ptoject is the seats. Gota deceide wheather to use local shop or buy on line seat covers.
Posted on: 2011/7/7 15:41
Carol Burnett
Bakersfield Ca
2336 Posts
Not sure whitch tow truck My vett make look the best> LOL
jpg  IMG00055-20110314-1521.jpg (306.77 KB)
5144_4e15d6fbdf734.jpg 2048X1536 px
jpg  IMG00115-20110630-1357.jpg (373.18 KB)
5144_4e15d71634c92.jpg 2048X1536 px
jpg  securedownload.jpg (100.94 KB)
5144_4e15d72b53bbb.jpg 640X480 px
jpg  IMG00042-20110204-1656.jpg (150.00 KB)
5144_4e15d73c7b88c.jpg 1536X1152 px
jpg  IMG00043-20110204-1657.jpg (219.66 KB)
5144_4e15d7522ef11.jpg 2048X1536 px
Posted on: 2011/7/7 15:58
1Fast04Vert Re: weather striping for 87 corvette coop
You might find this interesting:
http://www.zfdoc.com/clutch_hydraulic.htm
Posted on: 2011/7/7 16:37
Bakersfield Ca
2336 Posts
Nice article we had palnned on replacing entire system again all parts under warrenty. I will try the leak down test it sounds interesting. Thanks for the advice
Posted on: 2011/7/7 16:54
Carol Burnett
There was also a problem several years ago where all of the new slave cylinders were made with a seal installed upside down. Unfortunately I did not save the instructions on what to look for to identify the 'bad' ones.
ps--you have a good looking C4.
Posted on: 2011/7/7 16:58
Bakersfield Ca
2336 Posts
One of the kids at the shop replaced the Clutch master cylinder left it over noght to bleed. He cleaned out all the lines and took apart the slave cylinder this morning . This morning he drove it the clutch felt good but grined some times going into reverse. He took apart the master cylinder because the fluid was alread black. He took it apart and found it showed ware in the center of the cylinder.
I think Bogus was on the right track with modification of the clutch. I went through all the serevice records the last owner had and he had replaced and turned the fly wheel. When we replaced the fly we also turned the fly wheel. We found from an old Corvette mechanic that the 87-89 corvette had a problem with the fly wheel. If you turned them you had to get a chim kit or you would over work the hydraulics and destroy the slave and master cylinder and build up resuide in the lines. He also suggested that we insulate the lines with some material. So when all the parts get in this is what we are going to try. We are going to replace the fly wheel also. Thanks for your help 95vette.
Posted on: 2011/7/7 18:13
Carol Burnett
The 4+3 hydraulics are more reliable than the ZF6 setup.
I can see an angle change causing issues, but the amount of material removed would have to be huge.
Now, if you turned it down AGAIN, you may be too thin. Hence the need for a shim or 2.
Bleeding them isn't hard. I find if you take the master off, have an assistant pump it up to vent the fluid out, then using your thumb, you can work the piston in/out to remove the air. Works quite well, actually.
Keep us posted. I am really curious how thin the current flywheel is. The Helm Factory Service Manual has all the dimensional numbers for you.
Posted on: 2011/7/7 18:34
Bakersfield Ca
2336 Posts
Will be putting it up on rack tonight and yanking transmissom. Thanks for the help. All parts should be in by monday or tuesday I hope. I am fairly certain it is going to be the Fly wheel. But been wrong before. It is only money. Lol
Posted on: 2011/7/7 18:56
Carol Burnett
Bakersfield Ca
2336 Posts
Well we removed the transmisson. The clutch which is 9-10 months old looks fine. The flywheel had areas of Blue like it had been heated up or was slipping. My parts guy said he would warrenty the entire Hydralic system master ,slave,master cylinder to slave cylinder hose, and replace the clutch. I have ordered a new flywheel and should have all the parts next week.
I tell you it is great having close friends.
Gotta get to the Beach before I have to go back to work in Aug
jpg  Pismo Beach.jpg (410.79 KB)
5144_4e17a709ca3ce.jpg 2048X1536 px
Posted on: 2011/7/9 0:56
Bakersfield Ca
2336 Posts
Old fly wheel on the edge of tolarance. New one and new clutch and presure plate. putting pan back on after replacing rear main seal. Any one know what all the plugs on the transmisson look like . Found one that goes to the CAGS. Most of them are melted but working. Do they make a harness or does someone have pictures of what the plugs look like. Have a few Jeep wireing harnesses in good shape.
jpg  IMG00116-20110711-0824.jpg (187.25 KB)
5144_4e1c7ef30dc28.jpg 2048X1536 px
jpg  IMG00117-20110711-0827.jpg (176.43 KB)
5144_4e1c8069c21d2.jpg 2048X1536 px
jpg  IMG00122-20110711-0835.jpg (352.07 KB)
5144_4e1c808a86719.jpg 2048X1536 px
jpg  new flywheel.jpg (199.54 KB)
5144_4e1c80d852410.jpg 2048X1536 px
Posted on: 2011/7/12 17:14
