152 user(s) are online (121 user(s) are browsing Forums)
movnviolation Can't get gear of of headlight motor for 89
Hesperia, Calif
188 Posts
Pulled the whole light out of my 89 to do it on the bench. Got everything on bench. Gear cover off. Gear is loose but can't get it to come out. Put small screwdriver through the shaft for leverage like instructions say still no go. I even gave it the finger, and still no go.
Like something is holding it. Any ideas?
Have new gears and bushings waiting.
Posted on: 2011/7/8 2:41
Mods
bogus Re: Can't get gear of of headlight motor for 89
Plastic gears? So break the damned thing off!
Posted on: 2011/7/8 3:30
TommyT-Bone Re: Can't get gear of of headlight motor for 89
Ya. If the finger doesn't work a hammer and screwdriver might. Taps ..... Love taps .....
Posted on: 2011/7/8 3:40
movnviolation Re: Can't get gear of of headlight motor for 89
Hesperia, Calif
188 Posts
Got it. The first one took me 4 1/2 hrs. Second one took me 40 minutes. Piece of cake once you understand it. Works like new.
Tommy, the screwdriver did the trick once I decided screw it. The finger just makes me feel better.
Thanks
Posted on: 2011/7/9 4:12
Mods
