181 user(s) are online (135 user(s) are browsing Forums)
Does it work?
istter1 87 Vett Cruise control
Bakersfield Ca
2336 Posts
When I bought this gem the Cruise control didn't work. I replace the instrument cluster and was told that the right one that worked with the Cruise control had to be in vehicle for it to function properly? I replaced mine with the right one . Still no go. What should I check that is not in the Haynes manual. Received lots of good information from other on other issues so far. Thanks
Posted on: 2011/7/9 20:52
1Fast04Vert Re: 87 Vett Cruise control
Most often it is the electrical switch on the brake pedal that goes bad. But first I would check that it is holding vacuum.
Posted on: 2011/7/9 21:38
istter1 Re: 87 Vett Cruise control
Bakersfield Ca
2336 Posts
Thanks will do next week after we install the new clutch. Still got a month to play with it.
Posted on: 2011/7/9 23:05
Carol Burnett
