301 user(s) are online (267 user(s) are browsing Forums)
[IMG]http:/...
istter1 ABS over size tires 87 vett
Bakersfield Ca
2336 Posts
The tire size are 18" and 19" 20" wide with C6 rims. Found a little rubbind off the plastic on the drivers side rear. Another question was will it be driveable with 16" spare tire. It was lowered an 1" in the front
jpg  securedownload.jpg (100.94 KB)
5144_4e1b20c2b2289.jpg 640X480 px
Posted on: 2011/7/11 16:14
1Fast04Vert Re: ABS over size tires 87 vett
Obviously the handling would be terrible, but you could also burn up the rear end.
Posted on: 2011/7/11 18:12
istter1 Re: ABS over size tires 87 vett
Bakersfield Ca
2336 Posts
handles great only problem has been the ABS light staying on. And losing the hydrolics on the clutch. We while we were replacing the entire clutch system took it apart it looks great ... Knock on wood. Lol
Posted on: 2011/7/11 18:59
Carol Burnett
BrianCunningham Re: ABS over size tires 87 vett
Posted on: 2011/7/11 20:53
I thought he was asking about running a 16" spare in this topic. At least that is what I responded to.
Posted on: 2011/7/11 20:55
Bakersfield Ca
2336 Posts
Woops i miss understood. Been a long day
Posted on: 2011/7/11 22:44
Carol Burnett
