143 user(s) are online (51 user(s) are browsing Forums)
volzfan Turn signal "hyperflash" issue
Kingsport, TN
306 Posts
Okay, this seems a little strange to me. First of all, I've had the "halo" style LED tail lights on this car for almost two years, with no issues. A few days ago, while just out cruising, when I turned on the right signal, it "fast flashed". I thought I probably had a front bulb burned out...so when I got home I looked at it.....but the front bulb was burning fine, and the rears were fine also. The next time I drove the car, the right signal worked OK! Yesterday, back to the fast flash....only on the RIGHT signal. Left signal, and hazard flashers work just fine. Anyone got any ideas? I know there are "hyperflash harnesses" available for sale (probably consist of some sort of ballast resistor) for LED systems, but supposedly these tail lights don't require them, and for the past two years, they have worked just fine. Has anyone else heard of this problem, or ??
Posted on: 2011/7/16 16:00
Vettes of the Smokies
tjpreul Re: Turn signal "hyperflash" issue
Check for a bad connection on the right side (sockets/splices). This was happening to my SIL's Civic, and it had a bad connection in the socket. However all of the lamps still worked.
Posted on: 2011/7/16 18:15
