233 user(s) are online (190 user(s) are browsing Forums)
JAG19651 1995 Corvette convertible Bose system
1 Posts
Hi
I just bought a 1995 corvette. The bose system was removed by the other owner.There is a cheap deck with four alpine speakers. I want to remove all this and put all new stuff.
I would like a double din touch screen
Good front speakers rears and amps sub box
anyone have system alreasy that you can share the part name and model numbers with me?
Thanx Joe
Posted on: 2011/7/25 18:30
istter1 Re: 1995 Corvette convertible Bose system
Bakersfield Ca
2336 Posts
Go to Auido section upper part of Forums section.. Bogus gave me some great info on. Post is broken speaker.
Smart people here.
Steve
Posted on: 2011/7/25 18:42
1Fast04Vert Re: 1995 Corvette convertible Bose system
Here is a link that you might like. As far as I know Dennis is now selling everything you need to put a double din in a C4. We bought and installed his system in the C5 and everything worked just great and the install was easy.
http://www.doubledmods.com/
Posted on: 2011/7/25 19:35
Matatk Re: 1995 Corvette convertible Bose system
22803 Posts
Joe - welcome to the forum. I moved this topic into a more appropriate area.
I would glance through some of our members' installs in the section. Here are a few links to get you started:
http://www.corvette-guru.com/modules/ ... php?topic_id=8378&forum=2
http://www.corvette-guru.com/modules/ ... hp?topic_id=11195&forum=2
http://www.corvette-guru.com/modules/ ... hp?topic_id=11093&forum=2
http://www.corvette-guru.com/modules/ ... hp?topic_id=15204&forum=2
You should also make a list of what you really want and need, and make a budget for yourself. A sub box will need to be custom, which isn't a big deal, but you won't buy it off the shelf. How much work you can do yourself will also affect your budget immensely.
Good luck,
Posted on: 2011/7/26 3:27
