200 user(s) are online (140 user(s) are browsing Forums)
klkordzi Transmission shifting too early
Pittsburgh, Penna
152 Posts
My 85 has an automatic transmission. I've reset the TV cable several times and the tans continues to shift very early. Even going up a hill it will shift into 3rd and cause the engine to lug. Any suggestions?
Posted on: 2011/7/31 13:11
RickAnthony Re: Transmission shifting too early
ASE Master Certified
Downers Grove, IL
703 Posts
Was it always shift early or is this something that just started happening?
Posted on: 2011/7/31 20:26
My Automotive Blog
CORVETTE SERVICE & REPAIR
RickAnthonyMotorsports.NET
klkordzi Re: Transmission shifting too early
Pittsburgh, Penna
152 Posts
I'm not completely sure. I just finished the car and have started driving it. I've taken it out in small trips around the block up until now and it always seemed to shift very quickly through the gears.
Posted on: 2011/8/1 0:14
Matatk Re: Transmission shifting too early
22811 Posts
What method did you use to reset the TV cable? Also, what do you consider too soon? What mph/rpm. Any mods done to motor/trans?
Posted on: 2011/8/1 17:46
Pittsburgh, Penna
152 Posts
I believe I'm in 3rd before 20mph. Will also shift into 3rd when going up hill and the engine then lugs. No mods to the trans that I'm aware of. I put aluminum heads, camshaft, roller rockers and headers on the engine. I reset the TV using the procedure in the FSM.
Posted on: 2011/8/2 10:25
22811 Posts
Mine was shifting way too early after the 383 build, too. Must have something to do with the power band/rpm changing??? I ended up buying the B&M governor adjustment kit to change the weights, but it's not necessary. You can remove the governor, shave the weights down, and reassemble and test. Repeat. Use 6d finishing nails to resecure the weights and springs, that's what the factory uses. That's free and easy. Otherwise the B&M kit is around $50.
Posted on: 2011/8/2 11:32
