273 user(s) are online (179 user(s) are browsing Forums)
19774x4 seals
petersburg, il
18 Posts
ive got a th350 auto trans that the seal on the shifter shaft is leaking. cant get at the seal with a pick, is there enuff casting if i put the new seal agent the old one and drive the old with the new without pushing the old seal too far in the trans. the only other way is to drop the trans down to get at the seal. any input please
Posted on: 2011/12/22 22:37
Matatk Re: seals
22947 Posts
I have no personal experience with this, but it looks like it's all over the internet. Here's a good site:
http://www.jalopyjournal.com/forum/showthread.php?p=6499357
I guess there's a tool for that, but I like this guy's shadetree mechanic method:
"INVISIBLEKID
Member
INVISIBLEKID's Avatar
Default Re: TH350 shifter seal
Drill it,insert screw,pull with side cutters. Check shaft for burs.... grease inside of new seal,use socket to install........Not rocket science guys...... "
Posted on: 2011/12/23 3:13
19774x4 Re: seals
petersburg, il
18 Posts
i know i can do that, but i have to drop the trans to get at it. was hoping for a better way then droping it, thanks
Posted on: 2011/12/23 15:13
Durango_Boy Re: seals
You know this might be a good time to upgrade things. Have you considered a swap up to an OD auto like a TH2004R? It's almost a direct swap, and even has very similar gears to the TH350 so 1 - 3 will feel the same and you'll get a 4th and OD when you hook up an OD controller. The drive shaft stays stock. You can use your stock cross member...though you have to turn the mount backwards...and you'll have a 1 - 1 detent connection with the throttle to figure out.
Posted on: 2011/12/23 15:54
19774x4 Re: seals
petersburg, il
18 Posts
thanks but i am very happy the way everthing is going for now. just trying to fix small things before next years racing
Posted on: 2011/12/23 16:00
