Ajetsprt | 1992 Need help with broken piece in steering column | ||
Hi,
I pulled my steering wheel tonight to replace it with a restored one and found that the sleeve (located on the steering column) that the contact wire for the horn goes to is broken. The sleeve has a channel in it that the horn wire pushes into and then the wire hooks in place under some pressure from a spring to keep electrical contact. Does any one have any idea where I can get this piece or the proper way to disassemble the column at this point? I removed the C-Clip from the shaft and could feel there is some type of spring behind it so I put the clip back in place while I checked with the experts here.. |
Posted on: 2012/1/21 3:33
joeld | Re: 1992 Need help with broken piece in steering column | ||
Here's a some good pictures, should help.
Joel http://domesticmisfits.net/forums/vie ... rvette+steering+clumn+fix |
Posted on: 2012/1/21 4:02
1989 Coupe,L98 automatic |
Posted on: 2012/1/21 4:11
bogus | Re: 1992 Need help with broken piece in steering column | ||
I think you can just epoxy that back together. I don't remember there being much load there.
Posted on: 2012/1/21 4:37
josephf31 | Re: 1992 Need help with broken piece in steering column | ||
I think that's the same part that was broken on my '91 (there were so many it's hard to remember LOL) but I think I was able to get it from either Corvette Central or Eckler's
Posted on: 2012/1/21 5:06
2002 Magnetic Red C5 6 spd LS1 convertible |
vetteoz | Re: 1992 Need help with broken piece in steering column | ||
Turn signal cancel cam http://www.ecklerscorvette.com/corvet ... elling-cam-1990-1996.html #7 in diagram http://i171.photobucket.com/albums/u3 ... eoz/electrical/Column.jpg |
Posted on: 2012/1/21 6:08
Dem's the one! You can even get them at NAPA for about $7 |
Posted on: 2012/1/21 6:34
Ajetsprt | Re: 1992 Need help with broken piece in steering column | ||
Thanks everyone...
Bogus I took your advice and used some epoxy and then JB Weld on it and it's working and all back together again. Vetteoz got me the correct part info so I am ordering it to have incase it breaks in the future. The horn did not work from when I bought the car and now i know why.. I have the car up on stands so I can remove all four wheels and give it a good cleaning in the wheel well area. I hope to post some pictures as soon as I finish. Thanks again... |
Posted on: 2012/1/25 1:14
