-=Jeff=- | Question on RCA length | ||
I need to run from the middle of these 2 amps:
to the Driver side storage box. I cannot go direct through the middle, I need to go around the side to it. I am thinking I need 2 meter not 1 Meter cables.. What do you think? |
Posted on: 2012/4/12 1:02
bogus | Re: Question on RCA length | ||
2 meter should be fine. Get Monster RCA cable. Best for EMF shielding.
Posted on: 2012/4/12 1:14
-=Jeff=- | Re: Question on RCA length | ||
What about the Knu Konceptz? |
Posted on: 2012/4/12 1:22
Matatk | Re: Question on RCA length | ||
Don't know the brand but as long as it's shielded you should be ok.
Posted on: 2012/4/12 2:01
I have a creative mount for my XM6 I am working on..
Although I will not tear the car apart unless I know I have everything to get it back together quickly.. I have had it out 3 times so far this year |
Posted on: 2012/4/12 2:03
ditto... never heard of it. |
Posted on: 2012/4/12 2:09
Really good stuff with decent prices..
http://www.knukonceptz.com/ I have these currently http://www.knukonceptz.com/productDetail.cfm?prodID=KRY2.4M running from the Radio to the amps, which would move to the input of the XM6 |
Posted on: 2012/4/12 2:11
I am currently waiting on an amp. Found one on craigslist, but the seller was an absolute flake. He replied asking for my phone, gave it to him, he never called. I replied "is it still available?" he said, come on up - yea, San Fernando Valley at 9pm on a Monday, not me. I then contacted him saying that weekend, I then recontacted him on Friday, saying "tomorrow" and he never replied. Asshole. It was a Rockford Fosgate 1000bd - 1000w mono... drool. |
Posted on: 2012/4/12 2:12
like I said in the other post I have an Elemental Nine.2 if that will work for you
Posted on: 2012/4/12 2:14
yea, thanks, but no where near enough power. The W7s are power hogs. Dual voice coil, figure 250-500 watts PER sub.
Posted on: 2012/4/12 2:17
ah gotcha..
Posted on: 2012/4/12 2:18
My extra Storage bin has been modded:
Posted on: 2012/4/15 23:41
which RCAs from Monster? I want to do a price compare
Posted on: 2012/4/16 0:26
I have the micro RCA's. Very thin wire. I would make sure you have enough voltage to kill any noise. Or run the RCA down the trans tunnel.
Love that xover! |
Posted on: 2012/4/16 17:28
I have the Knu Konceptz running from front to back.. I need these to go from the storage cabinet to the back where the amps are, but due to how I have the storage doors mounted I have to go around the side of the car. I might just go with another set of Knu Koncepts. the 6ft might be too long, but 3 ft will be too short
Posted on: 2012/4/16 17:52
You should be able to reach into the storage bin via the trans tunnel.
Posted on: 2012/4/16 18:00
NelsonV | Re: Question on RCA length | ||
On topic to the OP: Don't forget to run the RCAs as far away as possible from any other wiring to prevent induction of noise.
Off topic to Andy: Wanna borrow the 2-channel Arc out me Chevelle? I figure I won't have a use for it for at least a month or two. And you know it could be longer 1) based on precedence already set, or 2) if I decide to down-size and use only the 6-channel for the entire audio system. lemmekno Edit for amp specs: Arc Audio - Robert Zeff Signature Edition 2300SE - 2 X 334 watts @ 4 ohms; 2 X 649 watts @ 2 ohms; 1 x 1300 watts @ 2 or 4 ohms (methinks those 8W7's have dual 3-ohm VCs which would yield 1.5-ohm nom impedance wired in parallel) |
Posted on: 2012/4/17 6:12
Edited by NelsonV on 2012/4/17 6:28:40 Edited by NelsonV on 2012/4/17 6:29:19 |
yeah, I know about keeping Audio path away from power.. sometimes it cannot be helped, but I do plan on them being separate.
Again, I have to do a short run from the Driver side storage box to the back of the cargo area.. the trans tunnel ends before my RCAs will get to the destination. I think I will order the Knu Konceptz RCAs when I am ready for them. |
Posted on: 2012/4/17 12:06
