148 user(s) are online (97 user(s) are browsing Forums)
xccter New '71 A/C Hot Water Bypass Valve. 20* Colder at Registers :)
Downtown Annapolis, MD
461 Posts
I know it's a repro valve from one of the usual suspects ($35), but the difference is AMAZING!
Now the evaporator and heater core aren't fighting each other.
Don't know if anyone else has a 69-72 A/C car with so-so cooling, but this did the trick for me.
Mark
jpg  IMG01987-20120417-2058.jpg (260.22 KB)
1113_4f8f207deb294.jpg 768X1024 px
jpg  IMG01988-20120417-2109.jpg (210.06 KB)
1113_4f8f20999fc34.jpg 2048X1536 px
Posted on: 2012/4/18 20:15
´71 350/270 L48 Coupe
NCRS #48337
Matatk Re: New '71 A/C Hot Water Bypass Valve. 20* Colder at Registers :)
Glad it worked! Is that a vacuum operated bypass that works off a switch? Manual or automatic?
I noticed since I've bypassed the heater core last week or so that the car runs about 10* cooler.
Posted on: 2012/4/18 23:52
xccter Re: New '71 A/C Hot Water Bypass Valve. 20* Colder at Registers :)
461 Posts
Yes it's vacuum operated.
The valve is always open UNLESS "MAX A/C" is selected, at which time vacuum is applied to the valve and it closes off the flow of hot coolant to the heater core.
Mark
Posted on: 2012/4/19 1:01
NCRS #48337
Good to know, thanks.
Posted on: 2012/4/19 11:39
Trae1976 Re: New '71 A/C Hot Water Bypass Valve. 20* Colder at Registers :)
Johnson City, TN
832 Posts
Nice!  thumbup
My original valve had expired as well.  I've got a manual valve in mine right now and just open it for the cold days.
When I finally get around to bringing my climate control system up to par, I may put one of those back in.  Good to know it works as intended!
Posted on: 2012/4/19 11:55
461 Posts
Yeah. Yours is electric and plastic. Curious what kind of manual valve you're using?
http://www.zip-corvette.com/ProductDe ... ias=&ptct=SGR-SR&CTitle=&
Posted on: 2012/4/19 18:11
NCRS #48337
Johnson City, TN
832 Posts
Just a basic ball valve, like this:
Posted on: 2012/4/19 19:15
