164 user(s) are online (118 user(s) are browsing Forums)
1st Gear: 2.74
2nd Gear: 1.57
4th Gear: 0.67
Reverse: 2.06
92Polo Refresh my memory please...
91 Posts
I let a friend borrow my FSM or I would just look it up. Got a service ABS light today. Which pins do I jump and what buttons do I press to get the brake codes? It's a 92.
Posted on: 2012/5/10 18:23
BillH Re: Refresh my memory please...
Jump pins A & G, A is on the bottom row, far left, G is on the top row far right.
The "Fuel reset" bottons run the modules up & down
"Gauges and Trip Odo" moves thru the module to view codes
"Fuel info" & "Eng Met" moves thru those codes.
9.1 is the ABS
Posted on: 2012/5/10 19:35
Andy, seems that the "Tech Library" has disappeared.
Posted on: 2012/5/10 19:36
Code Description
21 RF Wheel Speed Sensor Error
23 RF Wheel Speed Sensor Open/Shorted
25 LF Wheel Speed Sensor Error
27 LF Wheel Speed Sensor Open/Shorted
28 Wheel Speed Sensor Frequency Error
31 RR Wheel Speed Sensor Error
33 RR Wheel Speed Sensor Open/Shorted
35 LR Wheel Speed Sensor Error
37 LR Wheel Speed Sensor Open/Shorted
41 RF Valve Solenoid Error
44 Pilot Valve Solenoid Error
45 LF Valve Solenoid Error
51 RR Valve Solenoid Error
55 LR Valve Solenoid Error
57 Cruise Control Data Error
Code Description
58 EBCM Internal Adjuster Error
61 Pump Motor/Relay Error
62 Tachometer Data Error
63 Valve Solenoid Circuit Error
64 TPS Error
65 Adjuster Assembly Error
66 Adjuster Assembly Control Error
71 EBCM Internal Error
72 Serial Data Link Error
73 Spark Retard Monitoring Error
74 Low Voltage
75 Lateral Accelerometer Error
76 Lateral Accelerometer (Signal out of Range)
83 Brake Fluid Level Low
CCM Code Reading ASR/ABS
EBCS Error Codes - Module 9.1
Posted on: 2012/5/10 19:39
bogus Re: Refresh my memory please...
20861 Posts
yea, it had a major bug... I need to resurrect it in some form or another.
I never really liked how it worked. Perhaps time to do something better.
Posted on: 2012/5/10 19:47
92Polo Re: Refresh my memory please...
91 Posts
Looks like error 25, well H25 since the car wasn't running. I just replaced that whole bearing hub less than 6 months ago. Maybe it's just a fluke. I'll have to keep an eye on it when I drive it home tonight and see if it comes back.
Remind me again what module 4 is? I got an H22 and H72 out of it as well.
Posted on: 2012/5/10 20:01
Module 1- CCM
4- ECM
9- EBCM
25 is Intake Air Temp High
72 is Gear Selector Switch Error
I'd clear them and not worry about em.
Posted on: 2012/5/10 21:15
Edited by BillH on 2012/5/10 22:46:37
91 Posts
Yeah those codes could have been there for years. They certainly weren't current. I don't think the ABS code is anything more than a fluke either. Just kinda made me wonder since I had just replaced the calipers and flushed the whole system. Kinda a "you gotta be kidding" moment.
Posted on: 2012/5/10 21:23
20861 Posts
Module 4 is the ECM...
the ABS is hard to predict. Reset it, test it again. it could be a bad sensor. Is H25 a front or rear issue? The sensor is in the front, on the upright in the rear.
Posted on: 2012/5/10 22:40
91 Posts
Left front wheel speed sensor problem is what it supposedly means. As you said the sensor is in the bearing / hub assembly. I had replaced that about 6 months or so ago and the new part is a Timken so I would hope it's not bad. I cleared the code and drove it home with no problems and the code did not come back. I feel like it was just one of those occasional little flukes that are bound to happen on a 20 year old car.
Thanks all for the information. It would figure that my FSM sits on the shelf gathering dust for probably 6 years and the one time I need it I've loaned it out to a friend.
Posted on: 2012/5/10 23:17
