92Polo | Refresh my memory please... | ||
I let a friend borrow my FSM or I would just look it up. Got a service ABS light today. Which pins do I jump and what buttons do I press to get the brake codes? It's a 92.
Posted on: 2012/5/10 18:23
BillH | Re: Refresh my memory please... | ||
Jump pins A & G, A is on the bottom row, far left, G is on the top row far right.
The "Fuel reset" bottons run the modules up & down "Gauges and Trip Odo" moves thru the module to view codes "Fuel info" & "Eng Met" moves thru those codes. 9.1 is the ABS |
Posted on: 2012/5/10 19:35
Andy, seems that the "Tech Library" has disappeared.
Posted on: 2012/5/10 19:36
Code Description
21 RF Wheel Speed Sensor Error 23 RF Wheel Speed Sensor Open/Shorted 25 LF Wheel Speed Sensor Error 27 LF Wheel Speed Sensor Open/Shorted 28 Wheel Speed Sensor Frequency Error 31 RR Wheel Speed Sensor Error 33 RR Wheel Speed Sensor Open/Shorted 35 LR Wheel Speed Sensor Error 37 LR Wheel Speed Sensor Open/Shorted 41 RF Valve Solenoid Error 44 Pilot Valve Solenoid Error 45 LF Valve Solenoid Error 51 RR Valve Solenoid Error 55 LR Valve Solenoid Error 57 Cruise Control Data Error Code Description 58 EBCM Internal Adjuster Error 61 Pump Motor/Relay Error 62 Tachometer Data Error 63 Valve Solenoid Circuit Error 64 TPS Error 65 Adjuster Assembly Error 66 Adjuster Assembly Control Error 71 EBCM Internal Error 72 Serial Data Link Error 73 Spark Retard Monitoring Error 74 Low Voltage 75 Lateral Accelerometer Error 76 Lateral Accelerometer (Signal out of Range) 83 Brake Fluid Level Low CCM Code Reading ASR/ABS EBCS Error Codes - Module 9.1 |
Posted on: 2012/5/10 19:39
bogus | Re: Refresh my memory please... | ||
yea, it had a major bug... I need to resurrect it in some form or another.
I never really liked how it worked. Perhaps time to do something better. |
Posted on: 2012/5/10 19:47
92Polo | Re: Refresh my memory please... | ||
Looks like error 25, well H25 since the car wasn't running. I just replaced that whole bearing hub less than 6 months ago. Maybe it's just a fluke. I'll have to keep an eye on it when I drive it home tonight and see if it comes back.
Remind me again what module 4 is? I got an H22 and H72 out of it as well. |
Posted on: 2012/5/10 20:01
Module 1- CCM
4- ECM 9- EBCM 25 is Intake Air Temp High 72 is Gear Selector Switch Error I'd clear them and not worry about em. |
Posted on: 2012/5/10 21:15
Edited by BillH on 2012/5/10 22:46:37 |
Yeah those codes could have been there for years. They certainly weren't current. I don't think the ABS code is anything more than a fluke either. Just kinda made me wonder since I had just replaced the calipers and flushed the whole system. Kinda a "you gotta be kidding" moment.
Posted on: 2012/5/10 21:23
Module 4 is the ECM...
the ABS is hard to predict. Reset it, test it again. it could be a bad sensor. Is H25 a front or rear issue? The sensor is in the front, on the upright in the rear. |
Posted on: 2012/5/10 22:40
Left front wheel speed sensor problem is what it supposedly means. As you said the sensor is in the bearing / hub assembly. I had replaced that about 6 months or so ago and the new part is a Timken so I would hope it's not bad. I cleared the code and drove it home with no problems and the code did not come back. I feel like it was just one of those occasional little flukes that are bound to happen on a 20 year old car.
Thanks all for the information. It would figure that my FSM sits on the shelf gathering dust for probably 6 years and the one time I need it I've loaned it out to a friend. |
Posted on: 2012/5/10 23:17
