234 user(s) are online (89 user(s) are browsing Forums)
Dads90 Lookie what I found !!
Pearland, Tx
318 Posts
I think I got a steal, jealous ??
Corvette Clutch Slave Cylinder 1989-1990 OEM 10147948 for 63.75 Hopefully its as new as they say it is.
Posted on: 2008/2/13 3:58
Rex_Ruby RE:Lookie what I found !!
Philly Suburbs
180 Posts
Pull it apart first and make sure the seal is installed correctly on the piston. The flare of the seal goes toward the fluid part of the cylinder.
Posted on: 2008/2/13 4:06
Dads90 RE:Lookie what I found !!
Pearland, Tx
318 Posts
Oh yeah, I intend on doing that. I know the history of this bad boy. ZF Doc has a good "How to" on this. I'll just put on the shelf until the present one dies. It already has some fluid gathering on the lower side. I'll be ready.
Posted on: 2008/2/13 4:26
FLYINLOW90 RE:Lookie what I found !!
Windsor Ontario Canada
514 Posts
Lucky Bastage
Because you may need it in the future means you have a M6.
Did I say Lucky Bastage???
Gary :thumbright:
Posted on: 2008/2/13 16:39
Dads90 Follow up
Pearland, Tx
318 Posts
Well I took the slave apart, got some info from Bill at ZFDoc about the tear down. The piston was stuck and took a soaking of brake fluid and air pressure to get it out. The seal was on backwards, turned it around, and cleaned the interior light surface rust with 1000 grit sand paper. Reassembled and planning on putting the old retaining clip on top of the new clip for added strength. It should be good to go.
Posted on: 2008/2/26 4:36
