freakd | 1/4 mile time | ||
14.88@91.1 mph
sound right????? i got a g tech performance meter :tongue: |
Posted on: 2006/9/18 17:15
CREWZIN | RE:1/4 mile time | ||
About in the ballpark, maybe a cou0le 10th off what you should be running if your stock. I'm mainly stock but with a chip. 14.2@95mph is the best I've turned. I'm running a 2.59 rear end which is good for turing but not 1/4 mile times.
Posted on: 2006/9/18 17:20
Alcee1 | RE:1/4 mile time | ||
Yeah, my 84's best time to date is 13.8, stock it would probably do 15.2. So that sounds about right
Posted on: 2006/9/18 18:39
Edlebrock Heads, 2030 cam, X-ram w/EGR, 1.6 R/R, Bored TB´s, AFPR, Pro-built Tranny, Vigilantly 2600, Transgo, Dana 44 3.54, Hardened Pushrods & Head Bolts, Custom performance chip, K&N, Double roller timing chain, Aluminum radiator & flex hose, MS |
CasetheCorvetteman | RE:1/4 mile time | ||
.... I'm running a 2.59 rear end which is good for turing but not 1/4 mile times. Mate i got rid of my 2.59 out of the 94 and swapped it for a 3.33 DANA 44. I can tell you now a 2.59 is not going for anything.... (unless you like cruizing at about 90mph+ ![]() |
Posted on: 2006/9/19 9:55
freakd | RE:1/4 mile time | ||
i have the 2.59 in mine, boo, i want a nice new rear, but that will come, after i build the engine
Posted on: 2006/9/20 20:18
xrcrx | RE:1/4 mile time | ||
My 84 ran 15.2@88 stock. With the 1.6-1 rockers it's running 14.7@92mph.
Posted on: 2006/12/1 7:21
Eric 84 Z51 Auto 05 Repsol Rep 00 TLR 1000 |
