159 user(s) are online (125 user(s) are browsing Forums)
teebee, more...
freakd 1/4 mile time
727 Posts
14.88@91.1 mph
sound right?????
i got a g tech performance meter :tongue:
Posted on: 2006/9/18 17:15
CREWZIN RE:1/4 mile time
Lecanto, Florida
78 Posts
About in the ballpark, maybe a cou0le 10th off what you should be running if your stock. I'm mainly stock but with a chip. 14.2@95mph is the best I've turned. I'm running a 2.59 rear end which is good for turing but not 1/4 mile times.
Posted on: 2006/9/18 17:20
Alcee1 RE:1/4 mile time
Los Angeles
277 Posts
Yeah, my 84's best time to date is 13.8, stock it would probably do 15.2. So that sounds about right
Posted on: 2006/9/18 18:39
CasetheCorvetteman RE:1/4 mile time
.... I'm running a 2.59 rear end which is good for turing but not 1/4 mile times.
Mate i got rid of my 2.59 out of the 94 and swapped it for a 3.33 DANA 44. I can tell you now a 2.59 is not going for anything.... (unless you like cruizing at about 90mph+ )
Posted on: 2006/9/19 9:55
freakd RE:1/4 mile time
727 Posts
i have the 2.59 in mine, boo, i want a nice new rear, but that will come, after i build the engine
Posted on: 2006/9/20 20:18
xrcrx RE:1/4 mile time
Webster TX
83 Posts
My 84 ran 15.2@88 stock. With the 1.6-1 rockers it's running 14.7@92mph.
Posted on: 2006/12/1 7:21
Eric
84 Z51 Auto
05 Repsol Rep
00 TLR 1000
