264 user(s) are online (211 user(s) are browsing Forums)
Transverse Leaf Spring
joeld Sealer around AC pipe
Any one have any suggestions of a good sealer to replace the factory "putty" around the AC lines where they enter the HVAC box?
I've got a fair amount of air escaping around the bottom pipe, need all the cold air on me and not the engine!
I've used plumbers putty in the past on other cars, but it dries hard and dosen't last long.
Thanks
Posted on: 2012/8/14 17:49
Matatk Re: Sealer around AC pipe
Look in my ac thread...it's called dumdum by body shops or something like caulk sealant strips. 3m sells a box of 60 strips for like $25.
Posted on: 2012/8/14 18:10
joeld Re: Sealer around AC pipe
Yea Mat, I've used strips like that in the past for sealing bolt holes, seat belt anchors, etc.
I'm thinking I'll just clean all the old sealer off good and run a bead of black silicone around the pipe.
I just don't like the looks of silicone as well as the proper putty.
Thanks
Posted on: 2012/8/14 19:52
Forgot to mention, the "term" used in the assembly plants for most of this type of sealer was rubber dough.
Posted on: 2012/8/14 19:55
flyboy Re: Sealer around AC pipe
3M "window weld" ribbon sealer for glass setting is what I used. Glass shop nearby? Maybe they could give you a gob.
Posted on: 2012/8/14 20:28
That's exactly what I tried to get from a local glass shop earlier. After about 10 mins of trying to explain to some tech guy what I wanted, I gave up and used some black silicone to seal it up.
Thanks
Posted on: 2012/8/15 1:09
Churchkey Re: Sealer around AC pipe
69 Posts
Yep, handy stuff. 3M calls it Strip Calk.
Posted on: 2012/8/15 1:22
Posted on: 2012/8/15 1:55
