295 user(s) are online (247 user(s) are browsing Forums)
« 1 2 (3)
LD85 Re: Vibration.... IS GONE!!!!
Indianapolis, Indiana
784 Posts
I just ordered new Spicers, straps and bolts from Denny's
Posted on: 2012/9/2 0:12
2005/Z51
bogus Re: Vibration.... IS GONE!!!!
jeez... make me wait another week... argh...
Posted on: 2012/9/2 0:48
784 Posts
All new joints straps and bolts are installed, the tune is way off right now, lots of back firing,,, so it will go to the tuner Monday for the crank trigger tune, I'll have him update me as soon as he puts it on the dyno.
Also, we'll see how much gain I get from dumping the cats too
http://mikenorrismotorsports.com/
http://www.facebook.com/pages/Mike-No ... torsports/137451412986081
Posted on: 2012/9/8 23:02
2005/Z51
now your just teasing me... ugh...
Posted on: 2012/9/8 23:45
784 Posts
The vibration is gone, the bad vibes came from the half shaft u-joint that was bad, so thanks to Bogus
Posted on: 2012/11/9 23:21
2005/Z51
Yay! Great news!!!!
Posted on: 2012/11/10 5:17
exactly. Put load on the yoke, and all bets are off.
It requires a small enough press anvil to poke it out without loading the yoke, and then using a large enough socket at the bottom to allow it to clear.
Do this hamfisted and you have messed up hardware.
Indexed means aligned, for the lack of a better term.
It means that the widget in question must be oriented in a specific direction or location, or else it won't work right. This can be applied to engines with real small quench areas, and the plugs have to be installed with the ground strap up, this means indexing the plug. Same with the drive shaft. If it isn't lined up to what it should be, where it was balanced with the rest of the drive line, then it would vibrate.
Which makes me wonder... how were these balanced? Were they balanced with the diff? Did this take out imbalance with the trans yoke? I guess the question is: How much of an assembly was balanced?
The driveshaft had to be indexed to the input shaft of the differential - this means if you didn't mark it, you had a 50/50 shot of getting it right! So I wonder... was the driveshaft originally match balanced with the diff, and then act of balancing the one fixed imbalance within the diffs rotating mass. If that is the case, any bets you need to get this rebalanced?
I would actually reach out to Bill Bidreau at www.ZFDoc.com, he may just have the answer to this question...
I know this is old, I was researching for a new member regarding his vibrations...
however, a follow-up... I asked Will Cooksey, former Production Manager at Bowling Green about the procedure to balance the drivelines.
He could not remember if they came in together or what. He suggest I reach out to Dave McClellan.. And I might bug him at some point.
Posted on: 2013/10/26 2:14
CentralCoaster Re: Vibration.... IS GONE!!!!
There's a section in the factory manual about how to balance the driveshaft. Sure that would compensate for sticking it on the yoke 180* off. With that said, I've never indexed any of my driveshaft/halfshafts.
Posted on: 2013/10/27 22:41
DanZ51 Re: Vibration.... IS GONE!!!!
Wallingford, Vermont
7 Posts
All this u-joint action, I just have to show off my best tool. It's a Tiger Tool u-jnt puller. I purchased it years ago and it has NEVER failed me. I have pulled joints out of some the nastiest (rusty) driveshafts you ever seen, without damaging a yoke or ear.
http://www.tigertool.com/assets/images/products/large/101051.jpg
http://www.tigertool.com/product/1010 ... =DisplayOrder&maxRows=10&
Posted on: 2013/11/30 16:23
that's a neat tool... but expensive!!!
Posted on: 2014/4/2 1:52
« 1 2 (3)
