166 user(s) are online (136 user(s) are browsing Forums)
Zel06 Trouble codes
Zeller
6 Posts
Went for a short drive and the engine and abs lights came on. Got the car home and put it on the programmer. This is a list of the codes. P0172-system to rich (bank 1), P0175- system to rich (bank 2), P0324-knock control system error, P0335-crankshaft position sensor A circuit, P0336-crankshaft position sensor A circuit range/performance, U0121-throttle/pedal position sensor A circuit. The car has american racing headers, vara ram intake, 160 degree thermostat. Never had it dyno tuned. Could that be the problem or is it maybe an electrical problem? Any advice would be greatly appreciated.
Posted on: 2012/9/29 17:33
Ultraman Re: Trouble codes
14742 Posts
What year is your car...? Did you do the mods or were they there when you bought it.....
Posted on: 2012/9/29 17:52
Zel06 Re: Trouble codes
Zeller
6 Posts
It's a 2006 Z06. Bought it used in 2008 with 8,000 miles on it. Put the mods on it in 2009 and always had the engine light come on from running to rich. Never had these other codes come up before.
Posted on: 2012/9/29 17:59
14742 Posts
Those are some healthy codes its throwing...how does it affect the running of the car....or is the car able to run?
Posted on: 2012/9/29 18:02
14742 Posts
The first thing you need to check is if your battery is 100%. If there is any doubt replace it with the correct one. Cold cranking amps and RC has to be up to what GM specifies. That can cure a lot of wierd electrical problems on the C5 and C6's....
Here is some info on one of the codes....
http://forums.corvetteforum.com/c6-z0 ... -position-sensor-diy.html
Posted on: 2012/9/29 18:10
Zeller
6 Posts
The first time you start it up its fine. But if you shut it off and try to re start it sometimes it struggles to fire back up. Runs very sluggish at times. Almost like the timing might be off.
Posted on: 2012/9/29 18:12
Zeller
6 Posts
The battery was dead the other day when I tried to start it. Put it on the charger and it was fully charged. Thank's for the help. I'll check the link you sent.
Posted on: 2012/9/29 18:21
14742 Posts
Forgot to welcome you to the Guru, I really like your car....
Sometimes the starter going out can cause it to throw some wierd codes...but the battery is the first place to start...
Posted on: 2012/9/29 18:23
Zeller
6 Posts
Thanks for the help and welcoming me aboard. The blade silver with the black strip looks sharp!!
Posted on: 2012/9/29 18:55
bogus Re: Trouble codes
Looks sweet!
I will need to fire up my GM service manual. I would not be surprised if those codes were somehow connected to each other. Perhaps a common bad ground wire? Something that simple can cause all sorts of issues.
I have a feeling we have talked before. Your problem sounds very familiar...
And yes, Welcome Aboard!
Posted on: 2012/9/29 20:25
Zeller
6 Posts
Thanks, I'll have to look into that and see what i can find.
Posted on: 2012/9/30 2:30
C2C3C4C6 Re: Trouble codes
Sandwich, Illinois
63 Posts
That sounds like a plan!
Posted on: 2013/7/18 16:28
