istter1 | ebay red cap dist under $70 | ||
been looking at these since I was in the pits at a race last weekend . The local are buying these for clay track racing and these are holding up well at 7000 rpm.
they are vacume advance For my new 383 stroker I would like one of these but I haven't found one that is non vacume advance. give me some advice on this . the price these guys are useing with coil cap berrings not bushing is under $50 delivered http://www.ebay.com/itm/SBC-BBC-Chevy ... Parts_Accessories&vxp=mtr |
Posted on: 2012/10/20 15:40
bogus | Re: ebay red cap dist under $70 | ||
Dave? Are you there Dave? Hal here... will Steve's 383 wind up to anywhere near 7K RPM?
Real bad allusion to 2001: A Space Odyssey. Daisy... daisy... |
Posted on: 2012/10/20 17:18
istter1 | Re: ebay red cap dist under $70 | ||
lol had no plans on going 7000 rpm. just talking about being tough and in expensive. my other dist has some fire damage to wires. ave vs hal http://youtu.be/HwBmPiOmEGQ |
Posted on: 2012/10/20 17:34
donhall | Re: ebay red cap dist under $70 | ||
Andy, are you aware of the origin of HAL? Use the letter that follows H, A, L. Of course, you knew that. |
Posted on: 2012/10/20 17:40
yes, one letter lower than IBM.
Posted on: 2012/10/20 19:34
vetteoz | Re: ebay red cap dist under $70 | ||
If you have injection you are out of luck EFI HEI dist is completely computer controlled ; not just non vac advance |
Posted on: 2012/10/20 22:49
Churchkey | Re: ebay red cap dist under $70 | ||
What vetteoz said.
Summit & other vendors sell red caps & high output coils. The red caps will work on our screw on cap distributors with a quick modification. Whiz wheel the "L" off the spring loaded distributor lock on screw. Remove the remaining pieces, use the hold down screws from your current distributor. Good Luck. |
Posted on: 2012/10/21 14:50
If you buy this dist the cap coil and rotor with free shipping are $39 I can't buy the orginal cap rotor for that price with a new coil, |
Posted on: 2012/10/22 4:32
