276 user(s) are online (220 user(s) are browsing Forums)
chevyalltheway Siemens 60lb Injectors
AR
1 Posts
I bought these injectors from you guys, product code FLO331. First question is how do you guys get these numbers? Using gas or N-Heptane? Can you convert your numbers for me? I have been dividing by 10.5 to get my lb/hr. Currently the majority of my injectors say the flow at 662 cc/min @ 43.5 PSI.
Most importantly do you guys have any injector data to help tune these things in besides the flow rate? Voltage offsets? Do you have spreadsheets on these injectors for the correct IFR instead of just calculating the IFR? Any data would be extremely useful.
Thank you,
-Kyle
Posted on: 2013/2/13 1:43
FICINJECTORS Re: Siemens 60lb Injectors
Gold Sponsor Vendor
117 Posts
Siemens 60 are rated at 39.15 psi. They are 63lb in a 43.5 rail. What year is the car
Posted on: 2013/2/13 2:00
bogus Re: Siemens 60lb Injectors
Kyle - it sounds to me like we have way too many measurements... cc's per min is different than a lb rating per hour...
Posted on: 2013/2/20 0:05
