229 user(s) are online (85 user(s) are browsing Forums)
-=Jeff=- Planning some winter changes
Bartlett, IL
573 Posts
I am doing some slight changes to the car this winter. Going back to the 3-way passives and new 4" speakers to see if that fixes the speaker issue.
BUT I want to move the amps to the back wall..
any suggestions:
Posted on: 2012/8/14 13:35
-=Jeff=-
1990 Corvette ZR-1 #1051
Durango_Boy Re: Planning some winter changes
What speaker issues?
I'm a fan of back wall mounting. I think it creates more usable space without affecting case cooling.
Here's how my system looks in my C3, though I have loomed the wiring better since the pic was taken. Much smaller space but it works out great.
Posted on: 2012/8/14 15:33
bogus Re: Planning some winter changes
20885 Posts
I actually think the wall mount helps heat... it raises the heat sinks and forces heat up, as it naturally goes.
With 2 amps, you may need a double layer wall rack, but it now comes down to space.
Posted on: 2012/8/14 15:43
-=Jeff=- Re: Planning some winter changes
Bartlett, IL
573 Posts
Durango Boy.. The pair of 4" speakers I have currently had issues when I bought them for $25. I am replacing them since I am able to for a reasonable price, I did not expect them to last as I was told upfront they had issues.
Bogus, by double layer do you mean stacked forward form the wall? I was thinking they will fit like they are now just on the wall.. I was going to build out 1" to had a spot for wiring.
What is the best way to mount on the wall?
Posted on: 2012/8/14 16:43
-=Jeff=-
Being that my back wall has close to 3" clearance between it and the gas tank, I just used bolts with huge washers to mount a carpet covered board and then the amps just screw to the board normally using screws.
With the amount of space I had I was able to start the bolts on the inside, and reach up from behind between the tank and the back wall and get the washers and nuts on and tightened. Friction held the interior side of the fasteners until it was torqued down good and tight.
The amp mounting board is just a 5/8" thick piece of plywood cut to fit the back wall, so I had plenty of configurations without having to overrun the borders of the board.
If you're looking to hide wiring behind the board, just space it away from the wall using plastic or aluminum bushings.
I guess it all depends on your access to the back of that wall. If access is limited, well nuts that expand on the back side like rivets might work great and then you don't need access to the back. Just measure and drill your pattern on the board. Transfer that to the wall, verify measurements and drill the wall and set fasteners.
Set and mark your wiring ports for cutting, carpet the board, and you're ready to put it all together.
Posted on: 2012/8/14 19:28
Bartlett, IL
573 Posts
yeah I don't have the space luxury behind the wall. I was thinking I could possibly utilize the current studs on the top that hold the carpet. I could put a couple of brackets there to come forward for mounting the rack. Also due to the shape of the complete back wall, the sides by the speakers will but stepped in order to fit it correctly.
I will use screws from the back side and use them as studs to hold the amps as I have them today. in the center I will have the RCAs run up a 'tunnel' to get the the connections of the amps. hopefully I can do the same for the speaker wires and the power.
I would need to make a 'lid' of sorts to cover the gap at the top but also could offer access.
I think once I pull it apart I will figure something out, I meant to do this last year but never got to it.. I am going to do it this year though
Posted on: 2012/8/14 20:21
-=Jeff=-
Bartlett, IL
573 Posts
So I started on some of the changes by beginning with the front..
I had purchased a set of front speaker boxes made by a member on CF.. I bought them in August... finally got them in Oct and I am just now getting to installing them.
I will get a picture of the untouched box, but here is the front 1/2 of the box with the speaker holes cut and it painted
Here is with Speakers installed:
Installed with the OEM grill cover removed to check for clearance
here is a spare grill to be sure speakers are not blocked
I was thinking of cutting the speaker grill area out of the OEM cover to expose the box with speakers and then wrap the carpet back.. so the trianglar spot would be open. ho that makes sense
Posted on: 2012/12/10 0:56
-=Jeff=-
20885 Posts
that looks nice... but I have my 6" drivers outside the box entirely, and the 4" and tweets in the doors.
Posted on: 2012/12/10 14:48
Bartlett, IL
573 Posts
I know..
Going this route first.. keeps the layout I have. I did get a second set of these boxes to try and fit a 6.5 speaker in
So what are you thoughts on the grill?
Posted on: 2012/12/10 14:53
-=Jeff=-
20885 Posts
it's a good grill. leave it. Protects the cone.
Posted on: 2012/12/10 16:02
Bartlett, IL
573 Posts
but the carpet cover does not help the sound..
plus I have grills on the speakers anyway
Posted on: 2012/12/10 16:57
-=Jeff=-
20885 Posts
That cover should be acoustically neutral. Is there an audible difference?
Posted on: 2012/12/10 17:05
Bartlett, IL
573 Posts
Key is should be.. I think muffles the sound a bit
here is my thought for the grill:
Posted on: 2012/12/11 3:28
-=Jeff=-
20885 Posts
oh, yea... I like that. Clean, open, but I would still run some kind of stiff cover - perhaps a metal grill?
I had metal grills over my 4" mids, and then to make them look nice, covered them in grill cloth... When I converted over to the Jag speaker grills, I was floored as to how much more brightness I gained by losing those cloth covered grills.
Posted on: 2012/12/11 16:49
Bartlett, IL
573 Posts
Yes that will be a metal mesh grill. I found a place that sells flat pieces in size that will work.
Posted on: 2012/12/12 4:26
-=Jeff=-
20885 Posts
sweet!!
Posted on: 2012/12/12 4:46
Bartlett, IL
573 Posts
Planning on ordering the metal mesh for the front this week
I did tackle the Rear though..
after 2 hours of cutting the old rack to make it fit, I came up with this:
Amps sitting on the rack:
I need to see if I have enough carpet for that and the floor I need to make in front of it. I also need to buy some 8 ga power wire too
Posted on: 2012/12/24 3:55
-=Jeff=-
20885 Posts
look'n great!! Nice fit. love the idea!
Posted on: 2012/12/24 4:50
Bartlett, IL
573 Posts
I just realized that there should be enough room behind the rack to put my Passive Crossovers too..
keeps them out of the way I suppose
Posted on: 2013/1/9 14:04
-=Jeff=-
20885 Posts
it's nice to hide them away. mine are currently under the seats, but I want to relo them...
Posted on: 2013/1/9 16:07
Bartlett, IL
573 Posts
Progress
Carpeted:
Amps mounted:
Just need to cut the wires back and connect them to the amps
Posted on: 2013/1/13 3:10
-=Jeff=-
Matatk Re: Planning some winter changes
22996 Posts
Looking good so far!
Posted on: 2013/1/13 19:55
Bartlett, IL
573 Posts
It is getting there.. It got colder so I will not be working on it for a few days..
need to decide how to make the floor between the storage bozes and the amp rack..
Posted on: 2013/1/14 13:54
-=Jeff=-
Bartlett, IL
573 Posts
front speaker grilles are done:
the grille carpet looks rougher then it is in the photo
Posted on: 2013/2/4 2:45
-=Jeff=-
20885 Posts
look'n GREAT!
Posted on: 2013/2/4 23:21
Bartlett, IL
573 Posts
Installed the grills I modded
Still need to clean up and vacuum but I will do that while the seats are out.
Posted on: 2013/2/16 2:31
-=Jeff=-
20885 Posts
sweet!!!
I need to get going on mine...
Posted on: 2013/2/16 2:34
Bartlett, IL
573 Posts
Hacking up bezels for the console:
94-96 Radio bezel and Console panel
Cut:
mod to lower right of radio bezel:
test fit:
I installed a 94=96 driver side carpet panel for the console as the fit and finish with the bezels in place will be better
Posted on: 2013/3/12 15:32
-=Jeff=-
22996 Posts
Why did you have to cut the console/panel?
Posted on: 2013/3/12 16:13
Bartlett, IL
573 Posts
because it is a 94-96 panel which wraps around to the pass side, while the 90 has the 'wall/divider' so it is a custom mod..
Posted on: 2013/3/12 16:34
-=Jeff=-
Bartlett, IL
573 Posts
Test fitting everything.. Still need to tweak a few things then wire it all
Posted on: 2013/3/24 4:39
-=Jeff=-
22996 Posts
Good job! Can you get some decals for the ZR1 key to make it look stock or are you just leaving it?
Posted on: 2013/3/24 13:45
Bartlett, IL
573 Posts
I need to find a place to do it.. but I bet I can get it done..
otherwise I will leave it without lettering
Posted on: 2013/3/25 2:41
-=Jeff=-
20885 Posts
What is the final finish?
Posted on: 2013/3/25 4:04
Bartlett, IL
573 Posts
The OEM 90-91 Metallic grey
Posted on: 2013/3/25 4:21
-=Jeff=-
Bartlett, IL
573 Posts
GPS antenna.. I was going to mount it under the panel. But I am not sure how well reception would be
Radio powered..
Posted on: 2013/3/26 2:44
-=Jeff=-
Bartlett, IL
573 Posts
All buttoned up.. for now
Posted on: 2013/3/30 1:35
-=Jeff=-
20885 Posts
awesome!
Posted on: 2013/3/30 2:53
Bartlett, IL
573 Posts
Manual switch for the Antenna..
I tried a hidden antenna but there is no good place for it.
I think it would work well here, but would need to figure out a nice mounting solution and paint it black
it will not fit under the Halo though
Posted on: 2013/4/9 12:48
-=Jeff=-
