BV85 | EARLY C4 HOW 2 MOUNT LOWER BRKT | ||
Has anybody mounted the later hood prop on a early C4. I could use some help with this. Picture would help alot.TIA
Posted on: 2013/5/5 1:51
BV85 | Re: EARLY C4 HOW 2 MOUNT LOWER BRKT | ||
Come on GURU'S some body out there has done this before. I really need help. TIA
Posted on: 2013/5/5 17:15
bogus | Re: EARLY C4 HOW 2 MOUNT LOWER BRKT | ||
You are swapping the scissors with the single ram?
What kind of problem are you having? Is something not fitting? Not lining up? I took these shots from my 92 FSM. Attach file: HoodStrut.jpg (90.04 KB) hoodhinge.jpg (93.26 KB) |
Posted on: 2013/5/5 19:25
My 85 has some metal lines by where the lower brackt is going to be mounted. But I think I've got it figured out.TIA
Posted on: 2013/5/5 20:58
pianoguy | Re: EARLY C4 HOW 2 MOUNT LOWER BRKT | ||
I snapped a couple pics of the mounts from my '96, if those would be of any help.
Posted on: 2013/5/5 22:07
metal lines? I am guessing maybe the AC?
Posted on: 2013/5/6 13:34
LD85 | Re: EARLY C4 HOW 2 MOUNT LOWER BRKT | ||
on My 85
[URL=http://s556.photobucket.com/user/LAPCO/media/49FE1C7C-1434-4F7D-99B1-2C6D56A0C334-4321-00000151C025FA1E_zps7e2f776f.jpg.html][/URL] [URL=http://s556.photobucket.com/user/LAPCO/media/6D891213-8440-4F70-BA0F-0AC95CAE90E6-4321-000001519A89624B_zps53d0d2db.jpg.html][/URL] |
Posted on: 2013/5/6 15:54
2005/Z51 |
oh, fuel vapour return. Got it.
Not sure exactly where you could relocate those lines... |
Posted on: 2013/5/6 20:42
LD85 are there two brackts for lower brackt? I'd like to thank all GURU'S for the help and support I've received from this form. TIA
Posted on: 2013/5/13 3:34
One upper and one lower, send me your email and I can send pics, GURU software is rejecting my uploads. |
Posted on: 2013/5/13 14:15
2005/Z51 |
