230 user(s) are online (203 user(s) are browsing Forums)
Also known as SMC.
The only issu...
pappyfreebird 97 c5
1028 Posts
49k easy miles , has a clunk er click sound right rear? when takin off,,,new tranny n diff fluids..shafts seem tight no wheel wiggle like bearing n couldnt move anything to think a bushing,,this a commin thang ?
um i did take her out n do sum figure 8s etc no help , um aw i did let the clutch out n then give her sum juice n boy de party started..she lit em up easy as chit..so i hadda do nuthar figure 8 n gave her lil juice there too n mo fo bros she took me on a ride like de scrambler at a fair woooofugggaaaannnhoooyaw..ok ony one louie but was great ..tell gots home n olady asked why the stiffie in me pants wahahahahahaa..aftar explainin me joys she werent jelous no mo..
Posted on: 2013/5/13 11:32
teebee Re: 97 c5
12368 Posts
Pappy, that isn't normal....the clunk that is, the stiffie is normal.
Maybe the half shafts from the differential. The other possibility is the Wheel bearing(s).
Posted on: 2013/5/13 12:18
Ultraman Re: 97 c5
14746 Posts
What rear juice did you put in the rear end? Did it have the posi trac additive in it? Some times when you change the rear end out it will clank a bit for a short while but that should all be gone in a short distance....
Posted on: 2013/5/13 15:06
pappyfreebird Re: 97 c5
1028 Posts
hey bruthas sarry so slow i been real busy here again..she made the clickie noise when got it thats why changed out fluids , diff i used mobil sym 75-90 LS so should be good in the slip department..it very well could be a body creak too..somthun in right rear ony once in awhilst n seems ony when like takin off n turnin a bit ..did pull on anythin wid a bushing etc too..but i had say lower control arms on jack stands , so loaded so to speak.....ive heard many a bayud u joints but never had 3 er 4 er more in a rear thou..she runs out perfect uddawise..any mo idears er ifn i figure it out ill shneek back in here ifn de back doors left opin again..be good rednecks ...
ps axle nuts seemd tight have 32 n 36 but mm but nawt 33 34 but tapped a tiny bit wid punch n no loosness that way
Posted on: 2013/5/16 0:38
teebee Re: 97 c5
12368 Posts
Hadn't thought about the positraction lube, Marcus. That makes sense.
Posted on: 2013/5/16 1:28
1028 Posts
hadrea up in air other day n shook n pulled and ony noise makes is in gear ifn roll hard back n forth on wheel you hear slope clank (like gm slop) but nawt in diff but seems hear it in both sides were half shaft meets wheel...otherwise couldnt make any noise
let me add this,,wheel rocks back n forth a bit before shaft evin twitches,,so is slop in wheel were they join normal
Posted on: 2013/5/17 16:38
1028 Posts
well ain positive yet, ony run her last night,,but did raise azz end n hadda use 1 5/16 3/4 ratchet n them axle nuts ony twitched barely could tell they moved ,,but dont hear that clickie no mo er um dint n run it hunert miles er so
Posted on: 2013/5/19 23:35
