djxib | Replacement Brembo Rotors | ||
My steering wheel has started to shimmy on light to medium braking, and it's clear that the rotors are on the way out.
They are the Brembo drilled / slotted type, the calipers are 4-pot (black). I'll post up a picture later, but need some advice on identifying the model number/type for replacement (I prefer the slotted-only type) and also best place to buy. Oh - I need pads too. Recommendations on street/strip occasional mountain run pads? Cheers! Andy |
Posted on: 2013/7/17 15:43
Andy 1996 Greenwood Collectors Edition LT4 Previously 1992 Convertible Polo Green. 383 LT1/LT4 forged/balanced. V7-YSi, Alky. 608RWHP... Now sitting at a dismantler with a salvage title. Still runs... |
Matatk | Re: Replacement Brembo Rotors | ||
Are they direct corvette replacement rotors or an upgrade kit with different calipers, etc.
Posted on: 2013/7/17 17:19
-=Jeff=- | Re: Replacement Brembo Rotors | ||
Posted on: 2013/7/17 20:56
bogus | Re: Replacement Brembo Rotors | ||
Also check with Tire Rack.
BTW, the C4 never came from the factory with 4 piston brakes. 2, yes, 1, for sure... 4? nope. The black, or Grand Sport, calipers were the same as the ZR1 or J55, but a little bit thicker and black. |
Posted on: 2013/7/17 23:29
He might have these Brembos
I am using Hawk HPS pads in the front and thinking of thme for the rear as well |
Posted on: 2013/7/18 0:14
If he has the same or similar brakes to mine then he neesd 330x28mm rotors Which I did not find at tire rack. I would like to find a pair of rear 2pc rotors to match my fronts though |
Posted on: 2013/7/18 0:18
correct.
Posted on: 2013/7/18 1:43
djxib | Re: Replacement Brembo Rotors | ||
OK so here are some pictures.
Jeff - thanks for the suggestions, I'll try racingbrake. Looks like mine are similar to the pictures you posted up except my calipers look slightly different. |
Posted on: 2013/7/19 12:47
Do you have a picture with the wheel off? Might help to find the right rotor
here is mine now: |
Posted on: 2013/7/19 13:14
very nice brakes.
How much rim do you need? |
Posted on: 2013/7/19 17:30
Nice! I'm honey-do'ed out the wazoo this weekend and work is crazy, however I plan to get some quality car time next weekend. I'll post pictures then. |
Posted on: 2013/7/20 11:21
A-Molds fit with them just fine |
Posted on: 2013/7/21 2:59
I wonder if my American Racing TT M's will fit them...
Posted on: 2013/7/24 17:07
they may.. hard to say
I have an interesting project I might try this winter involving these on the rear: |
Posted on: 2013/8/15 4:43
