corvetteronw | Draining Fuel Tank | ||
In the process of getting the C4 ready for the road and running/looking nice.
My crew of helpers and I are now installing a fresh TPI system that I got from someone on the CF. Thought I would drain the fuel out of the tank as I am not sure how it has held up for the too many months it has been off the road. I tried this tip: "Disconnect the fuel line at the filter, have a few big fuel cans ready, and run a piece of line into the can. Now run 12V to terminal G on the ALDL...your tank will evacuate very quickly. Be ready. Also be ready to yank the wire out when the tank gets close to being empty or you will burn up your fuel pump....they don't like to run dry." So - gave it a try. Nothing. Freshly charged battery, no fuel coming out of the inlet line and no fuel pump sound. Tried it with the key out of the ignition and again with the key in the run position. Interior lights and dash board light up so I must be getting juice. I cannot find the source for this tip - just had saved the printount from some forum or internet search from several months ago. Mine is an L98 (1991) and has the 12 pin diagnostic connector. We double checked and had the correct terminal (G is in the lower left corner according to my reference book). My reference book does show a diagram of a later 12 pin and 16 pin diagnostic connector and says, "The 1994-96 vehicles may use either a 12 or 16 pin DLC. There was a diagram of the 94-96 DLC also and it shows no terminal G. Any clues? Looks like I may just siphon the stuff straight out of the tank instead. |
Posted on: 2013/8/3 2:08
A VETERAN IS SOMEONE WHO AT ONE POINT WROTE A BLANK CHECK MADE PAYABLE TO THE UNITED STATES OF AMERICA FOR AN AMOUNT OF UP TO AND INCLUDING THEIR LIFE. |
josephf31 | Re: Draining Fuel Tank | ||
This is strictly a SWAG, but I thought there is a connection between the oil pressure switch near the distributor, and the fuel pump, so that if there is no oil pressure the fuel pump will not run. Or maybe if the distributor isn't spinning as in when starting/running, the switch won't close and thus no fuel?
Posted on: 2013/8/3 2:29
2002 Magnetic Red C5 6 spd LS1 convertible |
corvetteronw | Re: Draining Fuel Tank | ||
Distributor is not even installed yet. You are right - that is one of the things the ecm checks for. I will just drain the tank the old fashion way and keep on truckin.
Here is the start sequence for the L98: http://www.corvettebuyers.com/c4vettes/l98.htm |
Posted on: 2013/8/3 3:27
Matatk | Re: Draining Fuel Tank | ||
Are you running a power line directly from the battery to the g terminal? |
Posted on: 2013/8/3 4:10
Old myth. There is no fail safe to turn off fuel pump. Fuel pump runs through relay first. If relay is bad, once car sees 4 psi oil pressure while cranking it will energize the fuel pump. |
Posted on: 2013/8/3 4:12
From positive battery clamp to the G terminal. Now I did find that my battery terminal (threaded hole) was slightly stripped so I re-tapped it to get a tighter fit. Have not tried the procedure again though as my helper is busy now.
Posted on: 2013/8/3 16:17
Got R Dun. Used siphon hose. Got 5 gal and then it started sucking air. Now to put in some of the good stuff.
Posted on: 2013/8/3 20:12
Sometimes the old way is the best! |
Posted on: 2013/8/4 2:35
SpectatorRacing | Re: Draining Fuel Tank | ||
I'll take the 5 gallons of old stuff
I'll grab it on my way to Grattan over Labor day weekend. You should come up for the day, it's not far from Lowell. |
Posted on: 2013/8/4 2:45
aka Scaryfast |
Poured it in my son in law's '04 GMC 1/2 ton so it would mix with the other stuff. Some of the gas in there was probably 2 years old and who knows how much condensation?
Would love to go to the race course but still got to install new distributor, water pump, EGR elim kit, convert my 91 TPI sensors to work with an 89 plenum, change oil, refill with coolant, change plugs/wires, install throttle body, set timing etc. I hope the biotch snarts, farts and starts! Then paint the nose and tail and put her up for sale. Edit: Gots to figure out which one (or more) of my FX3 shock controllers is bad. I have a couple of replacements so should be ok. And then there is flushing brake fluid and installing 4 new brake hoses. I won't be leaving the garage for some time! (Lovin almost every minute of it too !) |
Posted on: 2013/8/4 3:48
