275 user(s) are online (161 user(s) are browsing Forums)
Ozzy HELP
4 Posts
Were is the CCM located so i can pull codes??? 92 corvette
Posted on: 2006/10/1 16:24
freakd RE:HELP
727 Posts
should be right under the dash, on the drivers side, next to the tranny tunnel, at least that's where it is on my 87
Posted on: 2006/10/1 16:54
freakd RE:HELP
727 Posts
what's the car doing???
Posted on: 2006/10/1 16:58
Ozzy RE:HELP
4 Posts
it is trembling. and when i go up a hill that is about three miles long at steady rpm (2000) service engine soon comes on
Posted on: 2006/10/1 23:45
freakd RE:HELP
727 Posts
a bad optispark?? just my first feeling
Posted on: 2006/10/2 1:22
CasetheCorvetteman RE:HELP
I seriously doubt its the opti spark. If it was i dont think the SES light wouldve come on, unless the car stopped. Id take a gamble on EGR or a fuel delivery issue at this stage.
The ALDL connector is under the dash just to the right hand side of the steering wheel. Join pins A and B together and then turn on the key. Dont start it, just turn it to on. Codes should then be displayed on the dash where the speedometer would normally be.
Let us know what the codes are and we can move forward from there
Posted on: 2006/10/2 12:36
90EXPVette RE:HELP
Martinez, Georgia
185 Posts
Yolu don't need to get to the CCM to pull codes...you get the codes from the ALDL connector beneath the driver's side dash.
Welcome to C4 vette codes it is very ....repeat very
important that if you are not savvy of working on your
vette ...you would be better off - taking your car to a
dealership for repairs on your trouble codes.
However if you feel that you want to dive right in ..than you
have come to the right place.First locate your car's alcl
this component is located just below the instrument panel and
to the left of the center console. Remove the plastic cover
the first two slots to your right are the A & B slots for a drawing of
the alcl module's picture is added below.
The A slot is the diagnostic slot and the B slot is the ground
slot. insert the computer key into these slots (with the engine
off) this is very important...now only put the ignition key
to on ( not start !!!) the check engine light will display a
code 12 which is one flash followed by two flashes.
this code will be flashed three times ..followed by the
trouble code stored in your car's computer.
what ever the code is it will be flashed three times.
have a paper and pencil ready and write down the
code .
Code #12: Normal No Codes.
Code #13: Left Oxygen Sensor Circuit.
Code #14: Coolant Temperature Sensor Circuit High.
Code #15: Coolant Temperature Sensor Circuit Low.
Code #16: Opti-Spark Ignition Timing System.( Low Pulse)
Code #21: Throttle Position Sensor Circuit High.
Code #22: Throttle Position Sensor Circuit Low.
Code #23: Intake Air Temperature Sensor Circuit Low.
Code #24: Vehicle Speed Sensor Circuit.
Code #25: Intake Temperature Sensor Circuit High.
Code #26: Quad-Driver Module #1 Circuit.
Code #27: Quad-Driver Module #2 Circuit.
Code #28: Quad-Driver Module #3 Circuit.
Code #32: Exhaust Gas Recirclation Circuit.
Code #33: Manifold Absolute Pressure Sensor Circuit Low.
Code #34: Manifold Absolute Pressure Sensor Circuit High.
Code #36: Opti-Spark Ignition Timing System. (High Resolution Pulse.)
Code #41: Electronic Spark Timing Circuit Open.
Code #42: Electronic Spark Timing Circuit Grounded.
Code# 43: Electronic Spark Control Circuit.
Code #44: Left Oxygen Sensor Circuit Lean.
Code #45: Left Oxygen Sensor Circuit Rich.
Code #51: Mem-Cal Error.
Code #52: Engine Oil Temperature Sensor Circuit Low.
Code #53: System Voltage.
Code #55: Fuel Lean Monitor.
Code #56: Vacuum Sensor Circuit.
Code #61: Secondary Port Throttle Valve System.
Code #62: Engine Oil Temperature Sensor Circuit High.
Code #63: Right Oxygen Sensor Circuit Open.
Code #64: Right Oxygen Sensor Circuit Lean.
Code #65: Right Oxygen Sensor Circuit Rich.
Code #66: A/C Pressure Sensor Circuit Open.
Code #67: A/C Pressure Sensor Circuit. (Sensor or A/C Clutch Circuit Problem)
Code #68: A/C Relay Circuit Shorted.
Code #69: A/C Clutch Circuit.
Code #72: Gear Selector Switch Circuit
Posted on: 2006/10/2 12:43
freakd RE:HELP
727 Posts
wow, that's great, i didn't know all those code, hope that this helps him out :thumbright:
Posted on: 2006/10/2 12:46
red_johnny RE:HELP
Awsome Joe!!
Posted on: 2006/10/2 15:05
90EXPVette RE:HELP
Martinez, Georgia
185 Posts
No problem, glad to help I've gotten my share from the forums :D But those are the codes for 92-93 only there are different codes for earlier C4's
Posted on: 2006/10/3 12:14
