200 user(s) are online (114 user(s) are browsing Forums)
Also known as SMC.
The only issu...
sliding Which head gasket
Zagreb, Croatia
326 Posts
I need a new head gaskets. What would you recommend? So far I had FelPro 1043, which is a bit thinner for higher CR. I would like to keep that. It's also smaller in diameter, which is better I think. Only problem is that I thinjk it's steel wire gasket and it made some markings in the heads.
What do you use?
I need a quality gasket.
Thanks.
Posted on: 2013/10/18 8:31
Matatk Re: Which head gasket
What was wrong with the fel pro?
Posted on: 2013/10/18 13:09
sliding Re: Which head gasket
Zagreb, Croatia
326 Posts
The problem wasn't in the gasket. It was a crack in the head that started the process. But after examining the head I saw that gasket made too deep marks. I think it's because #1043's have steel wire rings. And #1010's are with copper wire rings.
Posted on: 2013/10/18 18:09
My car I would run felpro. If you want to spend more to feel better, buy cometics.
Perhaps look through the online catalog and see if they have a thickness that suits your needs.
Will might be able to give you a specific recommendation.
Posted on: 2013/10/18 19:39
