210 user(s) are online (167 user(s) are browsing Forums)
BrianCunningham Friendly reminder to check your anti-freeze
Most anti-freeze only protects to -34 degrees F
Parts of the country are COLDER than that!
Posted on: 2014/1/6 17:34
bogus Re: Friendly reminder to check your anti-freeze
no kidding!
then again, it's supposed to hit 78 here today!
I need to flush mine out... it has this nasty brown goo everywhere... yuck-o-rama.
Posted on: 2014/1/6 18:59
corvetteronw Re: Friendly reminder to check your anti-freeze
Lowell, MI
I used to own a 23' Baja boat with a 454 Magnum engine. The Mercury dealer told me I did not have to worry about winterizing the block and outdrive until the outside temps got into the 20s. So it appears that there is a bit of leeway in there. Still, I would not tempt fate!
I used to work with a guy who had been a pipeline contractor mechanic when he worked in Alaska. He said that in extremely low temps such as -40F they would leave equipment running or shut it off and drain the fluids.
Posted on: 2014/1/24 15:48
Ron - Re: Alaska - absolutely correct!
Diesel at those temps turns to jelly... not good... A couple of friends in the USAAF mentioned that, as well as some news reports regarding cold in Alaska.
Posted on: 2014/1/24 17:43
BrianCunningham Re: Friendly reminder to check your anti-freeze
Alaska, did you see all the spin out in San Antonio TX today?
Seriously wacky weather!
Posted on: 2014/1/24 17:50
Matatk Re: Friendly reminder to check your anti-freeze
This is the freeway all winter long just east of us...very dangerous when it is wet/slippery:
http://www.chicagotribune.com/news/lo ... iana-crash-fatal-20140123,0,5324588.story
Posted on: 2014/1/24 19:39
