197 user(s) are online (94 user(s) are browsing Forums)
A Collector Edition, RPO Z15.
1996 only.
LT1/A4 or LT4/ZF6....
matts85vet what repairs/replacements while the engine is out
Toledo, Ohio
58 Posts
engine is out and at the rebuilders. i now have great access to different areas under the hood. what are some things i should do/check/repair now that the engine is out of the way?
Posted on: 2014/1/18 2:55
bogus Re: what repairs/replacements while the engine is out
mileage?
I would think check the harness over from top to bottom, replacing any bad connectors or weak split loom.
If it's an automatic, I would get the tranny out and have it gone over.
Mileage thing, the steering rack... otherwise, PS hoses.
Check the radiator out and the AC system - the condenser gets all gnarly after a few years.
clean everything... degrease... maybe even shoot a coat of fresh paint on the frame.
If you have the budget, I would consider a brake upgrade.
Posted on: 2014/1/18 4:19
joeld Re: what repairs/replacements while the engine is out
Perfect time to inspect the rubber section of the fuel lines.
Posted on: 2014/1/18 4:32
matts85vet Re: what repairs/replacements while the engine is out
Toledo, Ohio
58 Posts
thanks for the suggestions!
it's an auto, 105,000 miles
fuel lines were replaced from the filter w/AN braided stainless hose a few years ago when i put the miniram on. does that ever go bad?
Posted on: 2014/1/18 14:52
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x-
istter1 Re: what repairs/replacements while the engine is out
Bakersfield Ca
2336 Posts
What will your new engine be
Posted on: 2014/1/18 15:19
Carol Burnett
Toledo, Ohio
58 Posts
new engine: 383
scat 9000 cast crankshaft 3.75"
scat 7/16" forged i-beam rods 6"
SRP forged flat top pistons 5cc
Comp Cams 280XFI HR13 retrofit hydraulic roller cam 280/288 113lsa
AFR 180 heads 58cc
TPIS Miniram 1204
Posted on: 2014/1/18 20:50
Vette91 Re: what repairs/replacements while the engine is out
Germany
70 Posts
Checking harness over from top to bottom is a very good idea. Does a dealer exist where you can buy a new harness for a '85 C4? I also toy with the idea changing it to a newer one, maybe late 1980 or early 1990 ...
Posted on: 2014/1/18 21:29
I don't know how "replaceable" the harness is on these cars. There isn't a central plug, so the entire dashboard has to come out. It's an integrated mess... truly...
On the scale of 1 being easy, and 10 being brain surgery, this is an easy 12.
Posted on: 2014/1/18 21:33
