matts85vet | align auto trans with block? | ||
block is back from rebuilders and back in the car. i have the 700r4 bolted up to the block with the 6 bolts and the 3 flexplate bolts connected to the crankshaft. i noticed that the trans is slightly to the passenger side by about 1/32"
it's on the dowel pins. didn't notice how it was before i removed the engine. my question is does it matter if the outside shell of the trans is a little off as along as everything bolts up ok and it's on the dowel pins? or do i need offset dowel pins, or is that only needed for manual transmissions. thanks in advance! |
Posted on: 2014/2/6 3:56
85 coupe, 383, TPIS Miniram, auto 700R4, 3.75 gears, afr 180 eliminator heads 58cc, 12:1 compression ratio, comp cams 280XFI hydraulic roller cam, 1.65 roller rockers, 52mm throttle body, c5 calipers, hedman elite longtube headers, pypes dual exhaust w/x- |
bogus | Re: align auto trans with block? | ||
could there be debris in the hole or on the pin? seems odd to me, but it could also be age or a warping of the trans case...
Posted on: 2014/2/6 16:32
BrianCunningham | Re: align auto trans with block? | ||
Sure it's your transmission case?
Posted on: 2014/2/6 20:20
Personally, I would bet on a bet trans case ahead of a bent block face... cast iron vs aluminum?
Posted on: 2014/2/6 20:42
When it's on the pins is the shaft on the trans aligned with the crank?
Take some measurements with the trans off. |
Posted on: 2014/2/6 21:03
matts85vet | Re: align auto trans with block? | ||
thanks for the replies! i think i will unbolt everything and try again. is it possible to install the transmission dowel pins wrong? maybe they are bent? i just tapped them in w/a small hammer into the block. maybe they are not out far enough
Posted on: 2014/2/7 2:08
