249 user(s) are online (203 user(s) are browsing Forums)
Assembly Line Diagnostic Link
BV85 Wider Wheels
12 Posts
Need some help on installing wider wheels on rear of C4.TIA
Posted on: 2014/2/7 6:38
bogus Re: Wider Wheels
what kind of help?
Posted on: 2014/2/7 6:44
BrianCunningham Re: Wider Wheels
I run 335's on all 4
What do you need?
Street?
Track?
Drag?
Posted on: 2014/2/7 18:17
Schrade Re: Wider Wheels
What do you need?
Street?
Track?
Drag?
I was about to post BC had 335's on all the corners...
You still doin' Linux OS on your pc's there Brian?
Posted on: 2014/2/9 16:54
Except for the one that run SolidWorks yes
great OS
Posted on: 2014/2/9 17:31
Only thing I do in Windows is DataMaster, if I ever learn navigation...
(not tryin' to boost your thread there, OP)
Posted on: 2014/2/9 19:12
