306 user(s) are online (258 user(s) are browsing Forums)
These are commo...
corvetteronw Exhaust
Lowell, MI
Over the last few years I have purchased some new and some used parts for my 91 L98 coupe.
This is my second summer of being retired. Last year I got all the projects done around the house and so this is my "Corvette Summer".
My current project is redoing the exhaust. I am too cheap to take it somewhere plus I like to play in the garage. I have a used catless front Y and the rest of the system (cat, O2 sensor, rear Y with crossover and mufflers) are all from Corvette Central.
Any advice out there? My LT-1 style muffler tips are both cockeyed and seem to set in about 1" too far.
In fact, the rear Y is about 1" too far forward of its rubber hanger. I'm wondering if I shoved the cat in too far on the front Y (slip fit).
It is very difficult doing this without being able to stand and get full leverage.
Any advice is appreciated!
Posted on: 2014/6/13 3:08
Matatk Re: Exhaust
Are the tips squared when sitting on the mufflers off the car? Are they original to the mufflers or added on?
I think it is entirely possible the cat could be pushed in too far. Are there any measurements supplied by CC? Try moving it out a bit.
I would recommend using band clamps as well with the slip fit as opposed to standard clamps.
Posted on: 2014/6/13 4:05
corvetteronw Re: Exhaust
Lowell, MI
The tips came with the Magnaflow mufflers. I am thinking of using a pipe wrench to twist the pipe that attaches to the rear Y to see if that might make the adjustment. No instructions came with the mufflers.
Posted on: 2014/6/13 15:52
Matatk Re: Exhaust
Are the mufflers separate from the y-pipe?
Posted on: 2014/6/13 17:02
bogus Re: Exhaust
hm... this is a mind bender...
Posted on: 2014/6/13 17:37
Matatk Re: Exhaust
I think it's normal. When I had my magnaflow cat back it took some adjustments to get it sitting right. Just move stuff around a bit and then clamp it tight when done.
Posted on: 2014/6/13 22:16
Lowell, MI
Well, I got the left side ok but the right side is about an inch off. Gonna sneak down some back roads (don't have a current plate)and take it to a local mechanic who says he can heat the muffler's curved inlet pipe while his helper pushes on it to straighten it out.
While under the car I found a coolant leak at one of the clamps for the oil cooler. Just got back from NAPA with a new hose.
I have the nose, gills, rocker panels, headlight buckets, license plate cover off and prepped to paint. Looks like I am ordering base/clearcoat from TCP Global Restoration shop. It is priced reasonable and covers well according to a painter friend. $500 shipped to Michigan for primer, base, clear and all the required reducer/hardner.
Those rocker panels are interesting to take off. I have never done this on a C4 before. 4 stainless screws at the top, 2 screws at each end and 7 bolts on the lower side. It is difficult to see them with the car on the ground but they have quite a bit of road tar on them. Lots of dirt jammed in behind them too. Good thing I took them off. I am only going to rear cap loose and pull the marker and tail lights when I paint.
Eastwood has a nice "how to paint" series for anyone contemplating doing this.
Posted on: 2014/6/20 18:41
bogus Re: Exhaust
I can't wait to see the results!!!
I am considering shooting my front bumper... but for the cost of materials, I might let the shop do it...
Posted on: 2014/6/20 19:00
