screamin_conure | Kudos to FIC | ||
This weekend, I replaced these...
http://www.racetronix.biz/itemdesc.asp?ic=01D042x&eq=&Tp= with these... http://fuelinjectorconnection.com/shop/viewitem.php?productid=420 ...in my '92 coupe and I couldn't be happier. FIC now offers Bosch III injectors with the EXACT flow characteristics required by early LT1 Corvettes, and let me just say they are awesome! Years ago, I had previously tried a set of the yellow Bosch III units that FIC sold (and still sells), but those only flowed something like 19 lbs. per hour and left my fuel trims way lean. I swapped those for the Racetronix units which are a Lucas disc type injector. While the Racetronix injectors delivered the proper fueling and were a good, serviceable injector, they don't atomize fuel quite like the Bosch units do. My BLMs are bang on with no ECM reprogramming required. Better idle, smoother throttle response, and though I haven't had them in long enough to verify, I'm guessing a little better fuel economy. Just wanted to pass this along. If you have a stock or mostly stock '92 or '93 LT1 Vette and you're looking for an injector upgrade/replacement, for $180.00, you can't go wrong. Ron |
Posted on: 2014/7/28 17:38
bogus | Re: Kudos to FIC | ||
I have heard that Jon is tweaking the Bosch III injectors with great success.
Posted on: 2014/7/28 21:55
Matatk | Re: Kudos to FIC | ||
Good stuff! I had them rebuild my last set of injectors and was very happy with the service/turn around.
Posted on: 2014/7/29 1:14
